Limp mode blues
Old Oct 10, 2011 | 02:41 PM
gitfooh's Avatar
Limp mode blues
I have a 89 NA that I swapped with a JDM turbo. I swapped all the normal stuff like new harness,maf,turbo sensor. The engine runs great. Can rev up no problem. When I go to drive it is when the problem starts. 1st gear pulls great sometimes 2nd OK but always by the time I hit 3rd it goes into limp mode. I check for MIL code but get none. Is there a way that I can systematically test for what may be causing the limp mode. I removed the waste gate and actuator and it works fine. I sure would like to take this for a ride before winter sets in.
Any help would be appreciated.
Old Oct 10, 2011 | 02:58 PM
Bamato's Avatar
S5 T2
I don't have an answer for you. However, I was curious why you removed the waste gate?
Your OMP hooked up and working still?
Old Oct 10, 2011 | 03:04 PM
gitfooh's Avatar
I removed it for inspection, I did reinstall it. The OMP seems to be working. I assume if it wasn't I would get a CIL or a code.
Old Oct 10, 2011 | 03:11 PM
Bamato's Avatar
S5 T2
Ah, I misunderstood. I read as if you removed the waste gate and just left it off. I was wondering what you had hoped to accomplish aside from dump all your boost...
I was under the impression that a faulty OMP causes limp mode. Has it been doing this since the swap?
Old Oct 10, 2011 | 03:20 PM
gitfooh's Avatar
Yes it has been doing it since the swap. A faulty OMP will cause limp mode but I thought it would also trigger a CIL. Is there another way that I can test it?
dexter snoek
Sep 29, 2015 09:18 AM
