Ticking noise while engine is idleing. What could this be?
Old Jul 17, 2002 | 08:55 PM
I am looking at a 94 (5speed). My dad said he heard a ticking noise that sounded like the noise valves make when they are tapping (obviously not valves but its a good description). Is this an exhaust leak or is it normal? What else could it be?
Thanks,
-Charlie
Old Jul 17, 2002 | 09:49 PM
its really hard to say without hearing the noise but with the hood up on mine i can hear a distinctive taping noise
Old Jul 17, 2002 | 09:55 PM
Fd3BOOST's Avatar
Recovering Milkaholic
Your just hearing he rotors spinning around I bet. Relax I did the same thing when I first got a rotary.
Old Jul 17, 2002 | 10:13 PM
martini's Avatar
I think my power steering pump started ticket before it seized.
Just listen around and try to figure out where it's coming from. If it's just at idle, I suppose it could be the airpump..
Old Jul 17, 2002 | 10:42 PM
Quik 93 FD's Avatar
going ls
its prolly the power steering/ac pulley, make sure its tight. Mine did that and i replaced the belt and the ticking stopped .
Old Jul 18, 2002 | 08:21 AM
Wade's Avatar
I can hear my injectors clicking on and off.
Wade
Hyperite's Avatar
Vagina Junction
Aiiiiirpump. Disconnect the connector for a few seconds and see if it goes away. Don't leave it off or you'll ruin your cat, but a few seconds won't hurt.
~Tom
Old Jul 18, 2002 | 09:07 AM
r_ed_line53's Avatar
Cool Use a stethoscope...
...if you want to specifically know where it's coming from find a 2' to 3' piece of hose and put one side to your ear and the other near or around the ticking noise. You shouldn't have anything ticking, it's a fairly smooth motor. If it is the air pump, it should not be ticking constantly. If it is a constant ticking noise, more than likely it's going to be a relay, possibly not grounded properly. Good luck.
see ya,
car 53
Old Jul 18, 2002 | 10:18 AM
Rated R1's Avatar
Oji San
If it is a ticking I would not worry about it. If it is more of a whacking that diminishes as the car revs, I would walk away from this car. That is the symptom mine had right before it threw a corner seal.
Old Jul 18, 2002 | 04:25 PM
JONSKI's Avatar
5yr member, joined 2001
You must find out where it's coming from. MANY things under the hood can make a ticking sound.
-Jon
Old Jul 18, 2002 | 05:52 PM
WhiteRXseven's Avatar
IF all else fails..
Start your car at night and look into your engine bay..
It may be a bad spark plug boot. Spark arching to
the Upper Intake Manifold.
I had similar issue. For me was a bad wire.
goodluck
Old Jul 18, 2002 | 06:51 PM
Toadman's Avatar
Nomad Mod
Does the ticking speed rise with engine RPM?
Mine was a leaky exhaust manifold gasket. Sounds like it's right under the airpump. You could smell it if it was.
bURGRotary87
Aug 19, 2015 03:54 AM
rexhvn
Aug 19, 2015 02:59 AM
gtcd
30
Aug 19, 2015 02:44 AM
