Sponsored by: CARiD
Distributor > Timing + Advance Issues, please help!
Old Oct 9, 2011 | 10:37 PM
Mushiki's Avatar
Rotary Lover
Unhappy Distributor > Timing + Advance Issues, please help!
Hi everyone... my car is a pretty special one... mix of different **** from different cars
You can read my complete build here:
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/my-13b-na-build-thread-945483/
In a nutshell, it's the following:
  • 13B NA S4 Engine, Rebuilt 1400 miles ago
  • Pineapple Racing 6PI Large Streetport
  • Pineapple Racing EP2A Exhaust Port
  • Exhaust Port Sleeves Removed
  • Euro LIM (Valve-style AUX Ports)
  • S3 Distributor + DLIDFIS
  • BAC, Air Pump, AC, and some other stuff removed
  • OMP Removed (Obviously, running Premix)
Now to the problem... the car was running great, had plenty of power... sometimes had a tad more, some other times a tad less... but overall pretty good.
About a week ago, my brake booster craps out. The brake master cylinder was leaking a bit into it, eventually destroying it. So I took it to a shop and they rebuilt it. Good.
Now... I installed the rebuilt brake booster... no issues. I start the engine... no issues. Now... I take it for a spin, and the car feels like it has about 50% de power it had before... idles just fine, but I get sluggish acceleration, pretty aggresive backfires, RPMs going up in an irregular manner, bucking, etc.
I immediately assumed this was some kind of ignition issue, so I checked timing with a timing light. Strangely, no issues there... car idles at about 1200rpm, and I get 5* L/20* T (stock). The car still runs like **** though.
So... what now? Since the only thing I did for the car to run like this was fixing the brake booster... I thought it may be some sort of vacuum-related issue. Maybe the vacuum advance or something was working semi-properly with the leaky/broken booster, and the fixed one messed everything up for some reason...
So I disconnected the 2 vacuum hoses at the distributor and... the car runs better. Not 100% better, but I would say... 85% better.
Now... why would this happen? What should I do?
Thanks a lot for taking the time to read, and I look forward to any feedback you might contribute with
Old Oct 10, 2011 | 11:24 PM
Mushiki's Avatar
Rotary Lover
First... to correct my previous post, Leading is set to , and Trailing is at +20º
Engine's idleing at about 1100rpm, TPS is now set to 0.98k Ohm... was at about 0.8
So I was just checking timing again... and I noticed this...
With the distributor vacuum hoses disconnected, I was able to see the timing advancing progressively when pushing the throttle.
Now... with the vacuum hoses connected I tried the same thing... and I noticed that timing advanced VERY abruptly... I just feathered the throttle linkage and I could see timing going from to about -12º instantly... in about just a 100rpm difference (yes, a hundred).
Any ideas?
Old Dec 1, 2011 | 10:36 AM
markeddief's Avatar
It's chess, not checkers.
Did u ever figure out what the problem was?
alphawolff
Nov 17, 2015 05:57 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
Microtech
Aug 23, 2015 11:04 AM
20B Forum
Aug 19, 2015 01:47 PM
