Moroso Spiral Flow Mufflers
Old Jul 17, 2002 | 08:11 PM
lowrider65's Avatar
are these worth getting or will they be to loud or burn up they are only 50 bucks each need advice my old mufflers rotting off
http://www.jegs.com/cgi-bin/ncommerc...38&prmenbr=361
Old Jul 17, 2002 | 08:33 PM
mazdaspeed7's Avatar
mad scientist
I have one sitting right beside me, but I havent had time to make a new exhaust using it yet. Hopefully within 2 weeks I should have it on.
Old Jul 17, 2002 | 08:36 PM
lowrider65's Avatar
cool you have to let me know how it works out are you planning on running any other muffler with it or just the spiral flow muffler
Old Jul 17, 2002 | 08:49 PM
mad scientist
Ill also be running a pair of 24" glasspacks repacked with SS wool. Im going to have my dual outlet headers, a collector, the 3'in/out moroso muffler, then another collector run backwards, my 2 SS packed glasspacks, then a pipe exiting right in front of the rear wheels on either side.
Old Jul 17, 2002 | 09:05 PM
lowrider65's Avatar
how did you repack the glasspacks with SS
Old Jul 17, 2002 | 09:35 PM
autocrash's Avatar
Now with more 1st Gen!
Ok, doesn't that completely eliminate the purpose of the dual header in the first place?
A collector followed by another collector sounds fairly restrictive to me....
Old Jul 17, 2002 | 10:37 PM
mad scientist
Not really, considering the pipe size Im using. 3" for the single part, and 2.25" for the dual part.
Im using the dual outlet header because I already have it. I currently have a true dual exhaust, and Im not happy with it, so Im going to a tuned collected system. the already collected headers arent set up ideally, especially for a heavily modded car.
As for the glasspacks, I cut them open, stuffed with some heavy SS wool, and welded them back.
Old Jul 17, 2002 | 10:44 PM
autocrash's Avatar
Cool cool
Why not happy with the true dual??
Old Jul 17, 2002 | 11:03 PM
Rxmfn7's Avatar
Do a barrel roll!
Theres a FC i see crusing around my area sometimes, he has those mufflers on it. It sounds good, pretty low and deep tone. I've only seen it like 3 or 4 times, cant ever get to talk to him.
Old Jul 17, 2002 | 11:20 PM
mad scientist
Cool cool
Sounds like a weedeater on crack/steroids. Not to mention I would get more power out of a collected exhaust, a cleaner exhaust(main reason), and Ill shave about 30 lbs from my heavy *** mufflers.
Old Jul 18, 2002 | 05:52 PM
lowrider65's Avatar
Old Jul 18, 2002 | 06:01 PM
NZConvertible's Avatar
I'm a boost creep...
How is this supposed to "reduce backpressure"?
Last time I checked air liked to flow in straight lines, not in a spiral...
Old Jul 18, 2002 | 06:16 PM
autocrash's Avatar
but thats what it is... a weed-eater on crack!!
Gotta be proud of what you drive... lol....
Old Jul 18, 2002 | 08:08 PM
RETed's Avatar
All those "baffled" mufflers eventually blow the baffle welds, and you end up with a plugged muffler.&nbsp This is also true of the Flowmaster type mufflers with just welded baffles inside.&nbsp The rotary engine generates a lot more heat with stronger exhaust pulses that hammer these types of mufflers.
-Ted
Old Jul 19, 2002 | 01:43 AM
lowrider65's Avatar
Old Feb 14, 2005 | 04:04 PM
BATMAN's Avatar
oops
Old Feb 14, 2005 | 04:41 PM
SDrotary-FC's Avatar
@ pipnorcali
i just got mine in after the cat, i had to try something and it seems to be working well
( i'm running RB headers, to bonez cat , to moroso sprial tech to apexi N1) it sounds like a rx8 with a cat back
Old Feb 14, 2005 | 05:26 PM
BATMAN's Avatar
How many miles?
Old Feb 15, 2005 | 11:06 AM
@ pipnorcali
Originally Posted by This is
How many miles?
about 1,000 miles on it so far
Old Feb 15, 2005 | 03:39 PM
jreynish's Avatar
New Project on the Way...
Agreed, I don't understand how that would Decrease back pressure? I am not entirely sure I would believe that shot, Unless there is some sort of really ingenious Fluid Dynamic Engineering going on in that thing!
squirrels
Sep 1, 2024 09:52 AM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
Rotafuzz
Sep 30, 2015 09:55 AM
