Clutch problems
Old Oct 8, 2011 | 12:27 AM
Robftw's Avatar
Clutch problems
The pedal sticks to the floor, i pulled the master cylinder out and when i press the plunger down with a screw driver it shoots fluid, and returns but after a few squirts it will no longer fill up and continue squirting.
should i disassemble it and clean it out? it does not leak anywhere, i even tried adjusting the pedals plunger travel.. and attempted to bleed it. it did nothing to get the firmness back.
the fluid level never changes, it does not increase nor decrease in the cup
Old Oct 8, 2011 | 12:33 AM
EigthCypher's Avatar
Unorthodox Tactics
It might be the slave cylinder, I had the same problem and when I replaced the slave it went away.
Old Oct 8, 2011 | 12:36 AM
Robftw's Avatar
I thought this too, it happened on my old rx7 except the slave cylinder was leaking fluid, this one is not
Old Oct 8, 2011 | 12:38 AM
Unorthodox Tactics
Mine wasnt leaking when I replaced it, however the problem was solved. I think its a mechanical failure not just a leak.
Old Oct 8, 2011 | 12:45 AM
Robftw's Avatar
I'll pull it out and check, fluid wasn't coming out of the slaves bleeder anyways maybe something inside it just broke.
Old Oct 8, 2011 | 08:22 AM
Molotovman's Avatar
Ban Peak
You should just change both while you're at it. The whole project is less than $100 depending on where you buy the parts. Make sure you check the rubber clutch line for deterioration as well.
Old Oct 9, 2011 | 12:39 AM
Wms10th's Avatar
10th Mazda - 10th A.E.
Mine was doing just that. Replace or rebuild the cluch master cylinder. The fluid is bypassing the piston seal inside. No, the slave cylinder is not leaking. I replaced the clutch master cylinder with a new one from Mazdatrix. Works great. $52.00.
Old Oct 9, 2011 | 03:34 AM
J5sense's Avatar
Meh I would replace the master and slave cyl. throw in that nice stainless steel clutch line from mazdatrix too.
once one goes the other is right behind it and you save time and money in the end. You also get piece of mind knowing your hydrolics are legit.
Old Oct 9, 2011 | 10:10 AM
Robftw's Avatar
Picked up a slave from carquest for 7$, still the same problem.
I had my brother get inside the car and pump the pedal hard by hand.. tiny tiny bubbles were coming from the MC, its shot
at least a new one was only 17$, i got a new stainless flex line for $10
Having friends work at autoparts stores saves you money
Enzo1944
Sep 6, 2015 08:57 AM
vmerino
Sep 5, 2015 11:26 AM
