Front harness to fuse box
Old Oct 6, 2011 | 08:49 PM
jaggermouth's Avatar
Will TIG for 20b
I've started ripping apart my drive side front harness to remove wires that arent needed after my swap. I want to keep all lights and the charging/starting system.
I read to replace the dash harness, you need to rip apart the dash (duh) but if I want to replace only the front harness in the bay, is it possible to disconnect it from the fuse box while leaving the dash in place?
I'm looking at the fsm where it goes in to the firewall and the fuse box but can't really make it out clearly.
Thanks
Old Oct 6, 2011 | 09:13 PM
misterstyx69's Avatar
Retired Moderator, RIP
I've taken a couple of them out and they are not fun.
Seeing as you want just the lights and ****,I would be thinking of cutting the other stuff off after the firewall and looming the rest of it...
I have the same problem right now as I put in an Aftermarket Ecu and I want a cleaner bay too!
Old Oct 6, 2011 | 09:14 PM
87 t-66's Avatar
not a drifter
you would have to pull the dash to remove it. make sure you triple check what you are removing...you dont want to have to replace that harness (ask me how i know)
Old Oct 6, 2011 | 10:26 PM
Will TIG for 20b
I saw a post on Norotors and the picture shows the guy unhooking everything in the bay and PULLING it through the fire wall hole, removing excess wires as its hanging out of the driver side door. Does this seem right? I will remove the dash if I have to, just making sure I NEED to to accomplish what I want.
Old Oct 6, 2011 | 10:48 PM
post the name of that thread on NR.I would like to see it!
Old Oct 6, 2011 | 11:14 PM
satch's Avatar
Might be this one.
http://www.norotors.com/index.php?topic=2874.0
Old Oct 6, 2011 | 11:17 PM
Originally Posted by satch
I saw that..it makes me "hurt"!..I am not bendable as I used to be so If you can imagine a 51 yr old wiretuckin,that is how it would go...not too good!..lol!
Bumpers for Jagger.
Old Oct 7, 2011 | 01:07 AM
Will TIG for 20b
screw it...an hour later...
The Shaolin
Sep 14, 2015 07:50 PM
PhillyFC
Aug 21, 2015 06:36 PM
