Drifting Discuss Drifting and drifting techniques here.
stock flywheel
Old Oct 3, 2011 | 12:46 PM
dancer7's Avatar
CA stock flywheel
hey guys just wanted to get your opinion/knowledge on a clutch setup. my 7 is a daily driver for work and I'm starting to go to monthly drift events. anyone running a stock flywheel with act 6puck sprung clutch? let me know thanks guys
Old Oct 3, 2011 | 02:01 PM
TweakGames's Avatar
FD pro licensed driver
Need WAY more information. Car? Engine? Turbo? Power? Why keep stock flywheel? Honestly flywheel should be the least of your worries right now....
I THINK about ... 8 brap motors ago I ran the stock flywheel with the silly XTC (or something ebay) clutch, and it worked just fine on the NA-T. Later went to a spec stage 4 with lightweight flywheel and much more power and it was much more fun.
I will tell you one thing, DD and drifting do NOT go hand and hand. Trust me I know.
Old Oct 3, 2011 | 07:33 PM
slidinsilly's Avatar
truf..
before i pulled my motor i was running a stage 2 exedy sprung clutch with a resurfaced flywheel. i was n/a and i thought that it made drifting ALOT easier. a heavier flywheel is good for drifting b/c it is easier to keep the momentum of the engine going.
check out the drift setup thread tho to see what everyone is running
Old Oct 4, 2011 | 01:16 AM
Zenki FC3S's Avatar
\\TRASHTALK//
dude lighter= faster... lighther flywheel spins faster, so when you press the gas it hits redline quicker
get one
Old Oct 4, 2011 | 02:08 AM
dancer7's Avatar
i have a s4 turbo engine est 250hp... well i bought a used sr motrosport flywheel 9.5 but didn't come with a counterweight. do you guys know if i can use the stock one or ima have to buy one from sr rear counterweight?
Old Oct 4, 2011 | 04:04 AM
Zenki FC3S's Avatar
\\TRASHTALK//
yea use a s4 counter weight off a NA engine.
the turbo flywheel has counterweight built in
Old Oct 6, 2011 | 08:36 PM
dancer7's Avatar
aght sounds good... thanks guys ill be using the act 6puck sprung hd clutch and sr flywheel
Old Oct 6, 2011 | 10:25 PM
arghx's Avatar
rotorhead
umm you do know that 6 puck clutch will last 10k miles max? Don't use a puck clutch for this application.
Old Oct 7, 2011 | 02:39 AM
dancer7's Avatar
so go with the act hdss then? or whats more recommandable?!
Old Oct 7, 2011 | 10:12 AM
laramiejoe's Avatar
???? I used a 6 puck in my daily for way more than 10,000 miles, then drifted on it for like 2 years, then when I got a new daily, I put it back in that car, and drove it for probably 10,000 more miles, then sold the car.
Learn how to drive stick bro!
Old Oct 7, 2011 | 11:11 AM
TweakGames's Avatar
Same here. I used the same 6 puck setup on 3 engines, WAY more than 10k miles, multiple drift events.... before I switched to a SPEC on my RE build, just because I thought I would need it, but I don't think I did. When I took it off it was perfect.
Maybe not learn to drive a stick, but learn how to install a clutch properly?
Old Oct 7, 2011 | 01:40 PM
ilia's Avatar
Chicago
I have a 4 puck act with sprung hub, and a stock flywheel. I have had this setup for two seasons now, and drive the car every day until there's snow on the ground. No problems yet!
Old Oct 7, 2011 | 06:41 PM
^hearrd that
cristoDathird
28
May 30, 2019 08:47 PM
sYnth.
Aug 19, 2015 06:27 PM
Clacor
Aug 14, 2015 09:17 AM
