View Poll Results: your injectors?
venom
3.03%
delphi
3.03%
sard
0%
deatschwerks
3.03%
bosch gen1
3.03%
bosch gen2/3
18.18%
denso
13
39.39%
RC
30.30%
greddy/trust
0%
Other
21.21%
Multiple Choice Poll. Voters: 33. You may not vote on this poll
Fuel injectors: the good, the bad, and the ugly.
Old Oct 2, 2011 | 11:36 AM
gear_grinder's Avatar
Don't hate my V8
Hi, i'm may be looking to get a new set of injectors for my fc to replace my (most likely) defunked "Venom" injectors. I need a minimum of 720cc of fuel flow (aprox 69#) i wouldn't mind even going to 750cc or 800cc for the extra buffer. My engine management consists of Rtek 1.8 coupled with Apexi AFC Neo tuned via wideband (dyno/freeway tune)
I plan on posting a poll for every ones opinions on the various injector brands and types.
the brands i can think of ATM are:
Venom: mostly junk (modified stock injectors)
Delph/multeci: unknown/stock Garbage motors products
sard: factory s5
deatschwerks: 750cc peak&hold only?
bosch gen1: old fords and euro cars saturated
bosh gen 2/3: newer fords and many other cars saturated
denso: factory s4
RC engineering: #1 quality and reputation
Greddy/trust: mixed reviews
others??
I've seen some posts of ppl running delphi injectors in their 2gens, the good points are that they are for peak and hold systems, they are fairly cheap. However i have experience with the multec injectors and they are garbage so i'm debating on trying a set (almost anything can be better then my venoms). I'm also not sure if their body actualy fits the stock fc fuel rail and injector bungs on the intake manifold. some clarification would be nice.
thanks for the input.
Old Oct 2, 2011 | 02:36 PM
wjk0817's Avatar
DD
Rc
Old Oct 2, 2011 | 03:51 PM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
I only have experience with denso, rc, injector dynamics, and fords 1680cc injectors.
They all fit the stock rail. They all do their jobs as expected. I havent had a failure from any if them. If I were to chose one and stick with them, it would be ID. They have what I need, high impedance, great fitment to stock rails and great reputation. They also use the new bosch design.
Old Oct 2, 2011 | 04:33 PM
misterstyx69's Avatar
Retired Moderator, RIP
Heard great things about ID"s and the strict tolerances..
RC's are in my car right now,but I am switching to ID's in the spring.
Old Oct 2, 2011 | 04:42 PM
RotaryEvolution's Avatar
Sharp Claws
should take venom off the list, i have personally dealt with a car that had them lose calibration over a short period of time.
Old Oct 2, 2011 | 04:47 PM
REAmemiya_fan's Avatar
Passion for Racing
Does the new Bosch design atomize the fuel well?
Old Oct 2, 2011 | 08:16 PM
coxxoc's Avatar
Shooting for 500
I have bosch, and I'm happy with them. That said, if I were looking today, ID would be my choice. I've seen a car running ID2000s all around idle and drive around with no problems and drag guys swear by them.
Old Oct 2, 2011 | 08:20 PM
MMoore4545's Avatar
Don't forget Marren Injectors
Old Oct 2, 2011 | 08:34 PM
Don't hate my V8
about how much do the ID's run? 300per pair or more.
any idea about the delphi? what do the 750cc plus bosch injectors come out of?
Old Oct 2, 2011 | 08:39 PM
K-Tune's Avatar
FD Daily
I have actually had good success with the venom injectors in the past.
Though I currently use ID since they are very high cc and still saturated.
Old Oct 2, 2011 | 08:40 PM
K-Tune's Avatar
FD Daily
Old Oct 2, 2011 | 09:01 PM
my 1000cc from ID cost $230
Old Oct 2, 2011 | 09:07 PM
bumpstart's Avatar
talking head
+1 for the marrens
,, if you need rochy/ multechs in 800 or 1000 at least these versions are blueprint paired
( getting around the very ambiguous variances in the mass produced multech batches )
and fit straight into stock rails ( choose the "import" versions to get 11mm tops )
-and allow you to bin the dodgy plastic mazda atomiser cups
PS
i can get the 1000's to idle as good as stock,, even with a micro
,, fine enough to tune for 19 inch vacuum on mild ported engines
Old Oct 2, 2011 | 10:16 PM
Don't hate my V8
for each injector?
Old Oct 2, 2011 | 10:57 PM
for a pair.
Old Oct 2, 2011 | 10:58 PM
Don't hate my V8
http://cgi.ebay.com/ebaymotors/Delph...#ht_2917wt_939
any idea with this injectors??? fitment & performance?
Old Oct 2, 2011 | 11:30 PM
bumpstart's Avatar
talking head
multech body ( ball plug and seat design ),, 11mm tops,, 1 % blueprinted
pretty much same as the marrens ( multech 2 ) ( which are 800 and 1000 ) [ and around $100 US each ]
multechs do not cope well with injector clean solvents
( the plug design is supposedly self cleaning , multech2 are much improved,, ID them by the wider base spray difusser )
the main issue is batch variances ,, the 1% stuff means they are flow matched
( blueprinted )
they can have some issues fitting the primary rail locations on rotaries due to the bulky body
i find you may have to use a mazda base rubber ( or two if delete the atomiser )
to lift them so they do not foul the block with the bottom of the injector body
personally i find the best combo is 4 x 1000 marrens
,, for easy fit,, for overall price
and as they are finite enough for a normal idle,, and stage well with primitive ecu staging ( micro ) and still flow well past 400 rwhp
i have put them in a fair few cars and never had issues
however with the Rtek you probably need to keep the groupings within those sizings that suit the ecu staging
Old Oct 3, 2011 | 12:03 AM
bumpstart's Avatar
talking head
PS
some multechs don't like high fuel rail pressures and they are prone to seal shut at above 60 psi fuel rail pressures
i highly suspect these are the ones with the hi ohming motor windings
the ( 95 lb, 1000cc ) marrens i have used are fine at 15-20 psi boost
( up to 65 psi fuel rail pressures )
NB .... these are the low ohming ( 2.0 ohm ) peak hold versions
Old Oct 3, 2011 | 09:55 AM
Don't hate my V8
the saturated injectors dont like high pressure?? i know some gm cars with the original multecs and the multec2s run a pressure spec of 60psi nominaly +/-5psi
Old Oct 3, 2011 | 01:46 PM
Osirus9's Avatar
Jackstand Drifter
I have 4x1000cc Injector Dynamics Injectors and my car holds idle at 750rpms like a rock. Now thats a true testament to how precise those injectors are made that they can function perfectly at such a tiny pulse width. My tuner also recommended them, so that's another vote.
Old Oct 3, 2011 | 02:04 PM
tuscanidream's Avatar
T2 Duo!
Nice. What mods you running?
Old Oct 3, 2011 | 06:20 PM
bumpstart's Avatar
talking head
yeps,, recalls seeing a display on a test bench with some GM saturated multechs where they stopped working at 60 psi base pressure
pretty sure it may be still up there on youtube ,, suspect the author is on one of these websites also
again,,
will state that the later ev1 mutechs with the wide base spray difuser and peak hold type
( the 800 and the 1000 )
don't appear ( in application on medium boosted 13bt ) to have many of the faults of the earlier GM sized multechs
( like sealing shut or burning the winding regularly )
Old Oct 3, 2011 | 06:40 PM
Rob XX 7's Avatar
FC guy
yes, this is what IDs are, they are nothing more then "matched" bosch, no modifications done to them whatsoever. The data I think they admit to is 1:10 are slightly off from the others, so you get matched to each other not to a standard and there is no dumpster full of injectors that they reject.
been around a long time, and will continue to do so long after most have come and gone. They also sell the new style bosch injectors
Old Oct 3, 2011 | 07:27 PM
FullFunctionEng's Avatar
Registered User
There are no modification to the ID2000's. The 725's, 850's, and 1000's are modified. Here is a pic for you:
WTF is this 1:10 ratio you keep bringing up? I don't understand what that means... ID's are matched dynamically in batches of more than 200 injectors at a time. There is a standard and they do have waste from each and every batch that does not meet their standard. Not sure where you got that misinformation from...
Old Oct 3, 2011 | 07:38 PM
arghx's Avatar
rotorhead
Greddy injectors are rebadged Denso
