How long do you let your rx7 warm up?
Old Oct 2, 2011 | 12:47 AM
lunardeathgod's Avatar
I am just curious on how long you guys wait before you drive your car when you start it up.
Old Oct 2, 2011 | 12:53 AM
ApexHunter's Avatar
Hmm. Probably about 3min. 1min if I'm in a hurry. The engine will die for me at like every stop until it warms up (stupid no emissions).
Old Oct 2, 2011 | 12:56 AM
J5sense's Avatar
I always used to start and go. Untill I purchased a 2009 Cbr 1000RR motorcycle and realized the importance of warming up. On my honda I wait like 3 min. On the RX-7 i wait untill the cold Idle drops to about 1000 rpm about 5-7 min
I stay under 3k untill thermostat opens. As should anyone. although on hot summer days I just start and go and the car is warmed up when i get 5 houses away then I open her up. Cold weather takes longer.
Old Oct 2, 2011 | 01:12 AM
K-Tune's Avatar
FD Daily
Around 20 seconds.
Old Oct 2, 2011 | 01:16 AM
monkey1911's Avatar
I'll wait until the standalone starts dropping the idle down and ramping down the cold start enrichment. Normally 2-3 minutes, longer if it's really cold out.
Old Oct 2, 2011 | 01:21 AM
barkz's Avatar
very good! lol
Old Oct 2, 2011 | 02:09 AM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
start it up, idle for a minute, drive under 3krpm and not hitting boost until its properly warmed up to 180f
Old Oct 2, 2011 | 02:31 AM
turboIIrotary's Avatar
I start my car up put my seat belt on then go so 10 seconds or so, if it is very cold outside I will sit on my hands then when they are warm I start driving haha.
Old Oct 2, 2011 | 02:39 AM
SpeedOfLife's Avatar
rotors excite me
^^^ this. Idling til warm is probably worse for the motor than idling briefly then driving til warm, except for when it's downright stupid cold. Then you'd better have your winter grade oil in there or you'll be pouring two stroke in the spark plug holes to get it to start. Ask me how I know... although come to think of it I might have indeed had my winter grade in there, but it was -10*F if not lower.
Old Oct 2, 2011 | 05:31 AM
wjk0817's Avatar
DD
Start the car. Have a cigarette. And drive
5min
Old Oct 2, 2011 | 09:09 AM
beefhole's Avatar
Boosted. I got BLOWN!!!
I start it up, and how ever long it takes me to check for leaks determines when I start driving LOL.
Old Oct 2, 2011 | 09:59 AM
lim_fc3c's Avatar
1. Turn key on
2. wait for wide-band to warm up
3. Put seat-belt harness on
4. start in 2nd gear to bypass AWS
5. Hit wipers, air-con/defrost or w/e
6. take off keeping under 3K rpm
Old Oct 2, 2011 | 10:13 AM
Zero10's Avatar
I start it, wait about 20-30 seconds until the idle settles down just a little bit, then I drive away. I keep it under 3k RPM until the temperature gauge starts to register, and under 4k RPM until it hits normal operating temperature. From there I try not to red line it until the oil pressure settles down (usually about 5 minutes at operating temperature) but every once in a while I do break that rule.
I am also a believer that idling an engine until warm is a bad idea, idle it long enough to make sure everything is lubricated and be mindful of the revs until everything is nice and warm.
Old Oct 2, 2011 | 10:42 AM
Aaron Cake's Avatar
Engine, Not Motor
The time it takes to get my hand off of the key, adjust the radio volume, release the hand brake, shift into reverse and then let out on the clutch.
Anything more is just a waste of time and fuel. Also likely unnecessary noise pollution, knowing the exhausts that many people put on their RX-7s.
Old Oct 2, 2011 | 11:49 AM
SpikeDerailed's Avatar
This sh*t burns oil!
As long as it takes to hold its own idle, which is usually when the engine hits 110* on the prosport gauge. Did the emissions delete, but left the bacv and that is not working now -_-
Old Oct 2, 2011 | 11:57 AM
Wms10th's Avatar
10th Mazda - 10th A.E.
Same, same or +1.
Old Oct 2, 2011 | 12:09 PM
13bpower's Avatar
s4 for life
I usually let it idle for about 15-20 seconds then drive with the revs under 2.5k until the temp needle starts to move. then I keep it out of boost until up to normal operating temp.
Old Oct 2, 2011 | 12:15 PM
Spirit-RE's Avatar
Start the car, wait for it to idle good. Take that 5 minutes to remember I need to get a working BAC.
Old Oct 2, 2011 | 02:02 PM
R0tor R00ter's Avatar
I usually wait till the idle drops to around 1000k but if Im in a hurry then I just take it easy and no boost till norm temp.
Old Oct 2, 2011 | 02:07 PM
I did that all the time when I installed my rebuilt engine. Haha, sometimes taking over 5 mins, I was paranoid.
Old Oct 2, 2011 | 02:34 PM
Tofuball's Avatar
Jesus is the Messiah
This is basically what I do as well. The car warms up as you drive - why abuse it by idling?
Old Oct 2, 2011 | 05:05 PM
RotaryEvolution's Avatar
Sharp Claws
+2
there is a difference between driving the car and abusing it when it is cold.
the rotor housings and irons do not seal very well when the engine is cold so the coolant seals take a bit of abuse if you start boosting on a freshly started cold engine. heat expands the parts and seals the internals of the engine naturally.
i generally do not take any longer than about 20 seconds to start driving, but if you truly want the engine to last let it almost fully warm up before you beat the snot out of it.
people who let their cars idle for 10 mins to fully warm up before driving need a clue, that is just overkill and all you are doing is wasting fuel, just like using synthetic oil in the engine and changing it every 2k miles on an original S4 non turbo.... really? save the money and put it towards a nice dinner with a girl or something.
Old Oct 2, 2011 | 05:23 PM
KompressorLOgic's Avatar
I
generally i do not wait for the engine to warm up at all and then start driving normally, i do avoid any hard driving till the car has fully warmed up though.
some exceptions might be if the car has removed emissions and will not idle at all when cold then i might wait till it will hold an idle depending on how big of a hurry i am to leave somewhere.
Old Oct 2, 2011 | 05:29 PM
Derekcat's Avatar
Rotary Zealot!
lol, great quote!
Start, tap throttle to kill AWS, buckle up, set the music and go..
Old Oct 2, 2011 | 05:39 PM
datz's Avatar
GNARKILL
i live in phoenix so maybe a ten second wait untill i go.
