Tires, Rims,and The Speedo
Old Jul 17, 2002 | 03:12 PM
i HAVE GATHERED THAT 17" X 8 RIMS WILL FIT ALL ROUND A S5, WITH 225/50/17 (F) 245/50/17 (R)
My question is, A- is this correct without spacers or anything?
B- Does this affect the speedo?
Old Jul 17, 2002 | 03:21 PM
ALTurbo2's Avatar
If I did the math correctly, you would have to have a 245/45/17 in the rear the keep the rolling diameter the same as stock. Anything different than that should cause your speedo to be off. I don't know about the fitment, though.
Old Jul 17, 2002 | 04:13 PM
Icemark's Avatar
Re: Tires, Rims,and The Speedo
depends on the offset of the wheel, but it is my understanding (and someone may correct me) that a 245 will be too wide.
Old Jul 17, 2002 | 04:21 PM
Ryde _Or_Die's Avatar
I believe 245s will fit just fine with the correct offset rims. I have heard of someone going even wider, its the offset that matters though.
Old Jul 18, 2002 | 07:02 AM
87GTR's Avatar
I will be running these tire sizes once my dang wheels get off the slow boat from japan.
stock T2 is 205/55/16 24.9 tall
225/45/17 front 25" tall
255/40/17 rear 25" tall
front 17X8 +35
rear 17X9 +35
wheel is Enkie RP-F1
you could run 245/40/17 in the rear if you only have 8" wheels. this size is 24.7 tall so your speedo will be a litte off
what offsets are other people running with 8" wheels?
Old Jul 18, 2002 | 07:19 AM
87GTR's Avatar
http://www.miata.net/garage/tirecalc.html
use this tire size calc to find the right size
rx7jocke
72
Jun 17, 2016 03:48 AM
