What air pressure are you running in 45 & 50 series tires?
Old Jul 17, 2002 | 08:54 AM
SureShot's Avatar
Seduced by the DARK SIDE
I'm also want to compare optimum pressure vs. rear camber. All I know is 40 psi in 50 series rears at 2.5 deg camber gives real loose handling.
Old Jul 17, 2002 | 09:20 AM
SureShot's Avatar
The label on the tire says max 45 psi. So is 25 psi too low?
Old Jul 17, 2002 | 09:26 AM
Barwick's Avatar
SCCA Rookie
if you're going higher speeds, they recommend inflating them more. I just got my '90 TurboII so I'm not sure. Plus one tire has a slow leak
Old Jul 17, 2002 | 09:30 AM
Felix Wankel's Avatar
Super Newbie
I usually run about 32-35 psi cold since its so hot here, and pressure builds up with heat.
Old Jul 17, 2002 | 04:39 PM
mazdaspeed7's Avatar
mad scientist
I set mine to 42 PSI when theyre hot.
Rotospectre
Mar 28, 2018 03:33 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Wolf_
Aug 11, 2015 04:23 PM
