Power FC need help!!!! vta1 vta2
Old Sep 19, 2011 | 12:13 PM
hkp's Avatar
hkp
big turbo spoolin
i bought a pos fd that had been sitting in pieces, among those pieces was a power fc. i put a turbonetics 67mm turbo, a pair of 850s in the primaries, 1300s in the secondaries, an fjo wideband and the rest of the little stuff to make it work. stock ignition, stock fpr, walbro pump. after getting it all together i get her started up and thats when the headaches began, i have not cut the 4 wires on the main harness yet, what i did was disconnect power, adjust screw under throttle body to half turn out, restore power, go to settings, reset, power off, power on, delete twins, delete o2, change injector size and then start idle procedure. the car idles pretty weird but i let it go, then after it gets somewhere around 65 degrees it starts hunting up and down, up and down. so i have a look at the sensors and the vta1 is at .01 and the vta2 is .00. i tried moving the tps around, that changed the idle because of the throttle plates moving but did nothing for the tps signal. is the tps just bad or am i dealing with something else, i pulled the plug from the tps and checked for power, br/w to chassis ground and came up with 5vdc. any help is greatly appreciated.
Old Sep 19, 2011 | 12:19 PM
arghx's Avatar
rotorhead
so does the voltage (as displayed on the Commander) change when you unplug the sensor?
you really should cut the 4 wires though
Old Sep 19, 2011 | 01:15 PM
hkp's Avatar
hkp
big turbo spoolin
with sensor plugged in, both vta 1 and 2 are highlighted and read as stated above, with the tps sensor unplugged vta1 is highlighted and reads 4.87v and vta2 is not highlighted and reads 4.97v
Old Sep 19, 2011 | 03:59 PM
hkp's Avatar
hkp
big turbo spoolin
i really need to get more sleep, didnt install the tps correctly.
hkp's Avatar
hkp
big turbo spoolin
and i went back and cut the 4 wires, now to get started on making those 850s idle.
ttpower
Oct 2, 2018 08:44 AM
Detbyron
18
Oct 7, 2017 07:45 PM
T88Rx7
Power FC Forum
Jan 26, 2007 05:58 PM
Seppeku
Power FC Forum
18
Sep 25, 2006 01:45 PM
dhahlen
Power FC Forum
Nov 8, 2003 10:28 PM
