How To Fix TPS?
Old Jul 16, 2002 | 11:48 PM
bamrx7's Avatar
How To Fix TPS itself w/o replacing?
Anyone?
Is there a way to fix TPS w/o replacing it? Mazdatrix is asking $180 for it...Pretty damn expensive...
Old Jul 17, 2002 | 12:05 AM
Sniper_X's Avatar
no.
other than replacment of a cheap unit and you just have to check ebay for it.
Old Jul 17, 2002 | 01:56 AM
DCmina's Avatar
I can give you one if you pay shipping. S4 right?
I'm not sure though if it works since I got it from a junkyard and didn't test it.
Can one tell me how to test it using a HOM or something meteR?
Old Jul 17, 2002 | 06:03 AM
T2 Tsunami's Avatar
Stud Service
I wish there was some other way to get this replaced, other than the $263 tag at Mazdatrix for my TII S5, any suggestions?
Old Jul 17, 2002 | 06:18 AM
T2 Tsunami's Avatar
Stud Service
Also I have heard that when you install a new TPS, it self adjust. Is this true?!
Old Jul 17, 2002 | 06:40 AM
banzaitoyota's Avatar
What Subscription?
ONCE AGAIN!.....
GO TO FC3S.ORG
DOWNLOAD THE DAMN FSM AND READ THE THING
THERE IS AN EXPLICIT TEST PROCEDURE FOR THE TESTING AND INSTALLATION OF THE TPS.
A $10.00 METER FROM WALLYWORLD OR IN YOUR CASE PEPBOYS WILL DO THE JOB.
Old Jul 17, 2002 | 08:56 AM
HAILERS's Avatar
HAILERS
What makes you think its busted???? What year tps and car, please.
Old Jul 17, 2002 | 09:03 AM
SureShot's Avatar
Seduced by the DARK SIDE
If it works, but your VOM shows non-linear values as you press in the plunger, you can spray some contact cleaner in it, work the plunger a few times and blow it out. Home Depot and Radio Shack both have contact cleaner.
Old Jul 17, 2002 | 09:06 AM
Silkworm's Avatar
Has been.. hangin' around
Junkyard my boy.. Junkyard.
PaulC
Old Jul 17, 2002 | 09:45 AM
darkwaveboi's Avatar
Need donor car in Fairfax
how often does the TPS need to be adjusted? (how often does it sqeek its way out of alignment/
Jeff
Old Jul 17, 2002 | 09:51 AM
Sniper_X's Avatar
rarely if you tighten it rught.
but it needs seasonal adjustment if its really sensative.
Old Jul 17, 2002 | 10:21 AM
jimmyv13's Avatar
Round&Round not Up&Down
Jeff
Everytime I check mine, it's out of adjustment. Last night I set it at operating temp, went for a drive, checked it when I got back and it was out again.
Old Jul 17, 2002 | 10:24 AM
blu_gxl's Avatar
mine when i out it in adjustment is just funky the car acts funny no throttle responce and low speed driveability sucks
Old Jul 17, 2002 | 10:26 AM
Sniper_X's Avatar
You both have bad TPS's i bet.
Unless one of you is missing the lock nut on the screw?
Old Jul 17, 2002 | 10:33 AM
jimmyv13's Avatar
I am hoping that is what is causing my irratic idle problems. What is the actual "order", if it exists, when adjusting the idle using the TPS, BAC, and A/F screw?
Old Jul 17, 2002 | 10:40 AM
Sniper_X's Avatar
read the FSM for your car.
You dont adjust the BAC.
Old Jul 17, 2002 | 10:42 AM
T2 Tsunami's Avatar
Stud Service
Does anyone know of the cheapest price for the TPS and BAC?, I'm thinking of getting them replaced new. Which should I replace first?
Old Jul 17, 2002 | 10:50 AM
jmseven's Avatar
Asset is Wealth
A good buddy of mine that builds race spec RX7's told me that you can replace the TPS w/ any other TPS. ALL the sensor are the same EXCEPT For the brakets they sit on. The tabs can be pushed, which can be popped out. Then do the same with another TPS. For example, if you have an S5 you can use one S4 tps then do the harness switch by popping out the ends of the wires, and attaching them to your connector.
That's it....you must test them first to find a good one.
Good luck.
Old Jul 17, 2002 | 10:55 AM
jimmyv13's Avatar
I read the FSM, but it doesn't tell which to do first, I had to adjust the BAC, it wouldn't idle with the J-Spec version with no idle screw. So basically, I'm compensating by upping the idle with the BAC since there is a faulty component somewhere (probably the TPS).
Old Jul 17, 2002 | 12:12 PM
Piranha's Avatar
what 7
I've tried all 3 methods of setting the TPS, ohmeter, voltage, and lights. The lights are the easiest, and it works the best.. and thats what you are supposed to do according to the FSM. But, you can't check to see if it is bad unless you use the ohmeter.
Old Jul 17, 2002 | 12:14 PM
blu_gxl's Avatar
where is the lock nut? i'm getting a new tps soon so i will see if that is the problem i am suspectng it is. also sniper i have another question it's from another post but this one will do i looked at my leading coil yesterday and saw one wire that was not connected it's te black there is 3 wires 2 are connected to the wthe coupler for the (guessing) ignitor. the last one (black wire) has what looks like a snap connection but is not connected to anything?? is this supposed to be connected to anything.
Old Jul 17, 2002 | 02:01 PM
HAILERS's Avatar
HAILERS
Jimmmyv13.....per the 87 manual you adjust the idle on your turbo by inserting the initial set coupler and adjusting your bac's screw. Prior to that I'd check the timing. But then again, don't set the timing if your idle is straying above approx 1000rpm because the ECU will start advancing the timing around that figure.
Never seen a jamnut on a tps. Ever. Sounds like a one off.
Old Jul 17, 2002 | 02:41 PM
Sniper_X's Avatar
NOpe, all series 5 cars have jamnuts. (locknuts)
ANd the black wire from your coil SHOULD be loose, there is also one in the leading coil...
Its a Tach signal for the factory timing light!
MUAHHAHAHah
hit me with another one!
Old Jul 17, 2002 | 02:45 PM
blu_gxl's Avatar
OK READ MY OTHER POST IT'S THE HELP W/ DIAGNOSIS POST
Old Jul 17, 2002 | 02:46 PM
blu_gxl's Avatar
AND HERE IS A LINK
https://www.rx7club.com/forum/showth...threadid=97081
