headlights won't work (not a simple solution)
Old Jul 16, 2002 | 11:33 PM
hercdriver's Avatar
OK here's the deal. The headlights were on adn then shut off and went into the down position. They won't pop up unless I use the overide button, and in no case will they turn on. I've replaced the fuse (all of them). Any other ideas?
Old Jul 17, 2002 | 10:29 AM
hercdriver's Avatar
bump
Old Jul 17, 2002 | 10:40 AM
jmseven's Avatar
Asset is Wealth
Do you have the stock alarm system. It is possible the the retractor signal from the alarm ECU has failed.
Also, you might have a burnt relay.
Old Jul 17, 2002 | 10:41 AM
Rated R1's Avatar
Oji San
Your headlight switch may also be bad.
Old Jul 17, 2002 | 11:33 AM
jspecracer7's Avatar
1JZ powered
Re: headlights won't work (not a simple solution)
Funny, this happened to me YESTERDAY....
...Look on the Driver's Side of the engine bay. If you're standing in front of the car and looking at the engine, look to your right where the fuses are. There will be ONE relay there. That is the one that you will need to replace. I had the EXACT same thing happen...
Old Jul 17, 2002 | 01:20 PM
hercdriver's Avatar
The relay being the one in the top fuse box or the one by the four relays attached to the green metal bracket. Thanks
Old Jul 17, 2002 | 01:23 PM
1JZ powered
The relay I'm talking about is not in a fuse box. I guess it would be attached to the green metal bracket...I removed quite a bit of that stuff or relocated it when I went FMIC
Old Jul 17, 2002 | 01:36 PM
hercdriver's Avatar
Cool, thanks for the help. Just to be sure you are talking about the black plastic one? It doesn't have anything else that looks like it anywhere near it. Thanks
Old Jul 17, 2002 | 01:44 PM
1JZ powered
It's covered with a black rubber insulator to keep water out(but it doesn't work too well with typhoon's)...
...either way, it's the ONLY relay within that vicinity. When you take the cover off, it should be a green relay(I'm looking at it right now....it's sitting next to my computer)...that's the color that my bad one was either way.
...To get your car running though, you could put your head lights up, then go and take the retractor relay out and replace the bad one with that one.
Old Jul 18, 2002 | 01:06 AM
hercdriver's Avatar
I finally got it. I (see my pic under moron in dictionary) tried to move some wires around last month and forgot to put it back in place. So when I got the car wet the dam thing was upside down and tucked away and got wet. Thanks for the help.
Old Jul 18, 2002 | 05:26 AM
1JZ powered
Another person doing their own work...and another satisfied customer
Old Oct 22, 2014 | 05:43 PM
Mraxg7's Avatar
Exhaust leak fixed
Thread revival, I came across this same issue yesterday. Can anyone tell me what this relay is called or where I can find it? Thanks
Old Oct 23, 2014 | 08:46 AM
HalfSpec's Avatar
Resistance Is Futile
Lane
Old Oct 23, 2014 | 09:42 AM
Mraxg7's Avatar
Exhaust leak fixed
Thank you, mine isn't located there anymore which is why I had a hard time understanding what they were talking about. You're a good man
Queppa
Nov 18, 2024 03:47 AM
Claudio RX-7
Haltech Forum
Apr 23, 2019 02:50 PM
