Canadian Forum Canadian users, post event and club info here.
11.42@122mph S5 hybrid turbo
Old Sep 17, 2011 | 04:01 PM
FC3Sdrift's Avatar
Displacement Replacement
It was an AWESOME day!!!! nice and cool out. and they had scraped the track to get off all the old rubber and glued it all nice and good. they had the nhra bracket races goin on with some test and tune on the side.
I ran 11.42@122mph!!!!! im ****** stoked!!!!!
Old Sep 19, 2011 | 01:14 AM
2Fierce's Avatar
Cautious Angel
congrats!
ps been a long time, hows your son?
Old Sep 19, 2011 | 06:56 AM
88rxn/a's Avatar
tom port.. AKA streetport
good job!
which BNR stage is that turbo?
Old Sep 19, 2011 | 01:42 PM
2Fierce's Avatar
Cautious Angel
its not a bnr...
Old Sep 19, 2011 | 02:06 PM
Zhé's Avatar
raawwwwrf
more specs of the car and setup durin that run!
Old Sep 19, 2011 | 03:02 PM
FC3Sdrift's Avatar
Originally Posted by 2Fierce
congrats!
he's great , its his 1 year birthday tomorrow . it flew by . he can say quite a few things. he makes car noises now
87 TII chassis
S5 TII engine
pineapple med streetport and ep2a exhaust
3mm RA super seals
turbo has a/r .60 compressor, S5 turbine housing and s5 turbo manifold adjustable waste gate actuator 17.5 psi drops to about 15 at redline
old school greddy fmic set up 2 1/4" piping greddy type r bov
3" turbo back exhaust
6 x 550cc injectors 2 prim 4 sec
OS Giken twin disk clutch with the heavy flywheel and thicker disks
megasquirt 2 with the zeal daughterboard
pretty much full interior i swapped the power windows for manual
I made this walk around video of my car a couple days ago the first 10 second youtube messed up
http://www.youtube.com/watch?v=lQXMutVeAII
I should have quit while i was ahead lol. there was this event thing going on at night and they were raffling off 8 1 hour dyno time prizes. My best 2 runs at night were 11.54 and 11.61 I wasn't gonna make anymore passes but my buddy had his camera and i wanted to get a good run on video. so I went to make one more pass. hooked up good in first shifted to 2nd then boom I thought it popped out of gear but now every gear is neutral hahaha.I was scared I broke my diff but its good. Im guessing I snapped the output shaft or something. I've been beating on that tranny for over 4 years so it owes me nothing. I just need to find a replacement there was one that was local I was goin to buy for a spare a while ago but it sold last month.
So I got a video of my tranny breaking hahahaha
http://www.youtube.com/watch?v=u9KUT2HxJ_E
Old Sep 19, 2011 | 03:15 PM
Casual_John's Avatar
And that's with a 1/2 second reaction time.
Old Sep 19, 2011 | 04:48 PM
88rxn/a's Avatar
impressive!
bummer about the car breakin down....
who made the wastegate actuator adjustable? did you or did you buy it that way?
how is that beneficial?
also, i couldn't see/tell if the AFM is still on the car?
dont know much about megasquirt thats why im asking...
Old Sep 19, 2011 | 11:10 PM
FC3Sdrift's Avatar
I've never broke anything drag racing so it was bound to happen sometime.
the wastegate actuator was like that when I got it
It's beneficial cuz i get 17.5psi with no boost controller, It add alot more pressure on the wastegate door, I had to pressurize it to hook it back up after tightening it down
there no AFM the boost controller and all that stuff is just there cuz i havent taken it out yet. Im going to make a new harness for the megasquirt and clean the engine bay up this winter, right now im just using a jumper harness i made out of an old ecu socket
Old Sep 19, 2011 | 11:16 PM
Puck's Avatar
Nice run! Congratulations! Are you sure it wasn't just a half shaft?
And Casual John... reaction time has nothing to do with ET.
Old Sep 19, 2011 | 11:31 PM
FC3Sdrift's Avatar
I was grabbing them all checking them out and my drive shaft they are all solid it rolls free in gear. im gonna get it in my shop and pull the tranny out to see the damage if its not a disaster inside I might just rebuild it cuz the gears worked good.
when i put it in gear there's no noise or anything, just nothing
Old Sep 20, 2011 | 10:39 AM
Puck's Avatar
Put it in gear, look under. If driveshaft is turning, then it's rear end!
Old Sep 20, 2011 | 11:22 AM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
Was good seeing you there, nice car you built!
Like Puck said, check the driveshaft and see if it moves! I broke a stub axle once, car wouldn't move and nothing looked or sounded broken. They're about $100 at the dealership and could probably be found cheaper used. When I broke mine I was right where you were when you broke your car lol
Generally when you break a transmission they make horrible noises in addition to all the gears not moving the car. Sometimes 4th gear will still work if you're really lucky. (good enough to get you home)
Old Sep 20, 2011 | 08:40 PM
FC3Sdrift's Avatar
I gave the car a good look over today, it is my rear end
hopefully its nothing major
Old Sep 20, 2011 | 09:35 PM
FC3Sdrift's Avatar
I was talking to my buddy about the rear end and it clicked.
I guess I had a bit of a blonde moment ....when i went to check it today I put it in first with the ebrake on, Its on the road infront of my place still so i was laying on a somewhat busy street looking underneath. the driveshaft was turning . so I started thinking about my S4 TII diff being fucked and what my options are ,but I had saw the cv housing of the driver side axle was spinning by the diff but the axle wasnt turning. DUH! busted axle = no moving . I'm gonna take a better look tomorrow but im 99.99% thats what it is
Old Sep 20, 2011 | 10:01 PM
Puck's Avatar
Yep, that is exactly what is is. Stub shaft on the passenger side. Probably sheared it off just inside the housing (or not). Sounds very similar...
Old Sep 20, 2011 | 11:30 PM
Clubuser's Avatar
the diff is probably the toughest component of the drivetrain. I would think a u-joint or a half shaft would shear way before the diff gives.
Old Sep 21, 2011 | 01:59 PM
Terrh's Avatar
those stupid weakass axle stubs!
Old Sep 21, 2011 | 02:48 PM
FC3Sdrift's Avatar
I checked after work today,I'm 100% sure I snapped the drivers side half shaft.
with all the wheels on the ground, ebrake on. the drivers side cv joint and boot spin but not the axle
I ordered on from napa 120 with my discount..thats sweet!
cristoDathird
28
May 30, 2019 08:47 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
Machupicchu
Aug 17, 2015 08:27 PM
