Rear Camber Install question
Old Sep 15, 2011 | 02:00 PM
88fcNA's Avatar
I recently bought a camber arm to camber out my wheels after lowering it. I received my camber arm and i thought there was supposed to be two. I am use to 240sx thats why i thought that. I found out from the guy and other lil research that it is installed in the middle of the car on the rear sub frame. I looked under my car a little bit and could not find where to install it at. If some one could post a picture or post a good description of where it is located that would be very helpful! Sorry about the n00b question.
Thanks
Old Sep 15, 2011 | 02:29 PM
Wms10th's Avatar
10th Mazda - 10th A.E.
It is mounted on the rear crossmember to the left of the differential. I know it does not seem like it would control camber but it does so by changing the angle of the forward tilt of the suspension subframe...wierd...but true.
Old Sep 15, 2011 | 02:34 PM
stevensimon's Avatar
its also a huge pita for being only 2 bolts.
Old Sep 15, 2011 | 02:49 PM
88fcNA's Avatar
do they sell ones for each side? 240sx rear camber adjustment style (pic of a 240s rear camber arms)
Im looking for some cheap too.
Thanks
<a href="http://tinypic.com?ref=15i40hi" target="_blank"><img src="http://i55.tinypic.com/15i40hi.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Old Sep 15, 2011 | 04:54 PM
sharingan 19's Avatar
Rotary Revolutionary
No.
What they DO sell are adjustable individual camber links which attach the trailing arms to the subframe. They have been known to break when used as the sole method of adjusting camber. The preferred method is to use both; the camber link (which u already have) for course adjustments, and the individual adjusters to level it out side to side.
Bare in mind that the link uses the compliance of the subframe bushings to make adjustments, and the individual adjusters rely on the compliance of the trailing arm bushings. As such these bushings must remain stock as a harder bushing would not allow for adjustment. The exception being the trailing arm bushings which could be replaced w/spherical bearings.
Oh, and leave the 240 stuff on zilvia (w/the exception of wheel fitment) it if of no relevance in the land of rotors.
Old Apr 9, 2012 | 10:19 PM
thethingthatshouldnotbe's Avatar
Anti-Hero
Mines a bushing that goes on the hub
Old Apr 11, 2012 | 09:19 PM
MadScience_7's Avatar
Too old for this
QFT!!
And even bottomed all the way down, it doesn't pull out as much camber as I was hoping for.
Old Apr 12, 2012 | 12:56 AM
LoLsmileyFC's Avatar
Burps and Braps
Thanks
we all wish they make something like that as far as rear camber adjustment your only option would be individual camber adjusters or a camber vertical rod like the own that you own.
PAGE 13-25 Good luck =]
http://www.rotaryheads.com/PDF/2nd_g...suspension.pdf
Old Apr 12, 2012 | 07:36 AM
DCRotor's Avatar
https://www.rx7club.com/build-threads-294/white-1987-gxl-build-%7Blots-pics%7D-978464/page2/
post #50 bottom of the page.
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
RaY358
Aug 19, 2015 11:44 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
