widest you can go with 17s on stock 3rd gen fenders?
Old Jul 16, 2002 | 06:56 PM
JimmyJimboJet's Avatar
boost deprived
Question widest you can go with 17s on stock 3rd gen fenders?
i'm gonna go with 17"wheels all around, just wondering how wide i could go, wheel-and-tire-wise, on a 3rd gen with stock fenders, front and rear? thanks in advance
Old Jul 16, 2002 | 07:49 PM
SleepR1's Avatar
Anyone want to bring Jimbo up to speed on the perfect 17-inch wheel/tire fitment
Old Jul 16, 2002 | 11:29 PM
Nathan Kwok's Avatar
Well that depends if you consider rolled fenders stock . For totally stock fenders, everyone together now, 255/40 on 17x9 wheels with 45-50mm offset. Tada! If you roll your fenders you can go to 9.5 wide and 275 tires, with the right offset you may not even have to roll the fenders but its not a certain thing.
Old Jul 17, 2002 | 12:14 AM
boost deprived
wow, that's a lot bigger than i expected....that's all the way around or just front or rear er what? thanks for the quick replies guys
Old Jul 17, 2002 | 05:10 AM
SleepR1's Avatar
Cool
Thank you, Nathan!
Yes, I run 255/40-17 Yokohama AVS Intermediates on 9 x 17, 45-mm offset SSR Integral A2s all the way around. I have H&R sport springs, stock Showa R1 shocks, and Eibach sway bars fr/rr. I have absolutely NO RUBBING.
FWIW, I run a conservative, -1.2 degrees of negative camber fr/rr...
Performance is astounding...pretty much overkill on the public off/on-ramps, and just what you need on the autocross and open-track circuits
Old Jul 17, 2002 | 05:34 AM
boost deprived
thanks for the info sleep.
Old Jul 17, 2002 | 09:15 AM
SleepR1's Avatar
Jimbo,
If you want to go really wide with stock style coil springs and stock fenderlips, you can try 9.5 x 17 with 50.4-mm offsets. You'll need to go with Complete Custom Wheels though, as there are no Japanese aftermarket wheel makers that will have this size and offset available for the FD Rx7.
You'll still be limited to a 255/40-17 tire size (limited by overall tire diameter NOT tire section width), but you can pick the widest of the 255s, as each manufacturer has their own idea of how wide a 255/40-17 should be
IMO, the widest 255/40-17 R-compound tire is the Kumho V700 Victoracer. This size ends up being 10.8 inches wide on a 9.5-inch wide rim. This is AS wide as a typical 275/40-17!
The problem with going wider than 255/40-17 is that 265/40- and 275/40- 17s are all taller than the stock 225/50-16 (which is ~24.9 inches). If you go taller, you run the risk of rubbing the front fender lips with the taller tire size's outside shoulder blocks (inboard and outboard), when the suspension compresses while turning left or right.
Old Jul 17, 2002 | 01:17 PM
boost deprived
well i was looking at S-03s, SSR Comps in17x8.5 front and 17x9.5 rear, with Apex'i N1 coilovers all around.........i would most likely be doing the suspension and wheels/tires at the same time, this winter sometime. and rolling the fenders wouldn't be a problem for me...and i would be keeping the stock 16 inch wheels, new rubber on them and using them for autoX or drag or opentrack or whatever.
Old Jul 20, 2002 | 09:52 AM
SleepR1's Avatar
JimmyJet,
If I were going to put road tires on my SSR Comps, I'd go 235/45-17 (fr) and 255/40-17 S-03s.
If the Apex'i N1 coilovers are 2.5-inch outer diameter, I'd go full-bore and get CCW P4 Mesh in FIVE 10 x 18 (2-inch offset) with 285/30-18 Kumho Ecsta 700 tires--four to go all the way around, and the fifth to serve as a full-size spare if you're driving to/from open-track events.
You can use the stockers as road wheels/tires...
Old Jul 20, 2002 | 03:53 PM
boost deprived
what are the CCW P4 Mesh'sesessses?...
man, what a mess to say that word.
Old Jul 20, 2002 | 05:03 PM
SleepR1's Avatar
CCW P4 Mesh
John Purner (CCW founder) made a P3 Mesh wheel center originally for a 16-inch wheel diameter. When he began making 17-inch wheel diameters, he continued using the P3 mesh wheel centers. They became an issue with larger brake calipers and rotors (not to mention looking "goofy"), so he fabbed larger wheel centers (still in a mesh design), termed "P4".
Apparently John's up to his old antics, as P4 is currently used for EIGHTEEN INCH CCW WHEELS Perhaps if enough people complain he'll make a "P5" wheel center?
Note that larger wheel centers mean more weight...so there will be a compromise (life's just full of trade-offs!).
You're wondering what "P" means...if I had to guess...I would say "P" is for "P"urner...well wouldn't you name wheel designs after the first letter of your last name?
Old Jul 20, 2002 | 09:00 PM
Turbo_Rotary's Avatar
Major RX-7 Withdrawals
I wanted to know the same thing, except for a FC. What's the widest wheel and tires I can go with for the rear if I have Tein HA coilovers and I rolled the fenders (for 16 inch wheels). I don't really care too much about the front because I'm going to get the Mariah Motorsports E-Production fenders and I can just ask them. I already tried the search function, but it didn't come up with anything.
Old Jul 21, 2002 | 06:20 AM
bkapold@aol.com's Avatar
On an FC John @ CCW made some 17x 9's up front and 17 x 10's rear for some guy that works across from him...I'm not sure of the offset but needless to say that wide. Kevin Wyum has CCW's on an FD that are 17 x11's in the rear and 17 x 10's or 9.5's up front....He has 315 stuffed under there..What a site!
I have 17 x 9's on my FC and there is no rubbing..If your into track/auto-x might I suggest 245's x 4...It works great....You wil have to role the front fenders though....my .02 Brad
Old Jul 22, 2002 | 12:34 AM
Cool, thanks for the info Brad.
Old Jul 22, 2002 | 11:27 AM
DamonB's Avatar
A fellow RX-7 buddy just bought CCW 18x10's for all four corners. The fenders aren't rolled and he uses the same offset at all four corners. Unfortunately I already forgot what he said the offset was
He had to run coil overs up front to provide clearance, and the rears try to rub the sway bar when jacked up; at ride height there are no issues. He runs ASP and outran the Z06's without suffering any rubbing problems. And the car looks mean with 18x10's....
Old Jul 22, 2002 | 12:26 PM
SleepR1's Avatar
Question 10 x 18 for FD 4 corners offset
The offset was probably 2-inches (50.8 mm).
Old Jul 22, 2002 | 06:03 PM
boost deprived
I'm not too sure about 18's....they would look gigantic on such a small car...anyone have any pics?
Old Jul 22, 2002 | 07:04 PM
R1Outcast's Avatar
Mine are 275 - (40 or 35...I forgot ) in the back.
Low profile tires are hard to find in this size...but at least my rims don't get bent when I run over a pot hole.
Old Jul 22, 2002 | 07:05 PM
R1Outcast's Avatar
Oh, and they're 17's.
Old Jul 22, 2002 | 07:57 PM
I love black wheels like yours.. I have a dark gray color now...
and I think that offset is either 40mm or 35mm...Buy CCW wheels, for the money there is nothing better.....Brad
Old Jul 22, 2002 | 11:19 PM
SleepR1's Avatar
10 x 17 CCWs are tough because the rears need wheel spacers to clear the rear trailing arms...this precludes rotation...10 x 18s are much better...
Old Jul 23, 2002 | 07:20 AM
Rotary Master
I am running 17x8.5 with 245/40r17s up front and 17x10 with 26540r17 out back on stock suspension and stock fenders on my FD with no problems. However, I have Fikse FM/10s that were custom made for the car. AS for the offset, I don't remember, however if you call Fikse or Rishie, they can tell you.
Old Jul 23, 2002 | 07:08 PM
R1Outcast's Avatar
Originally posted by bkapold@aol.com
I love black wheels like yours...
Mine are actually painted black. They were all silver but since they're two-piece, it was easy to keep the black and silver separate. I've seen them all black (no silver lip) but it kind of looks like you're riding on four spare tires .
Old Jul 23, 2002 | 09:15 PM
the all black look has really got'n out of hand with the Honda, Neon, crowd....Its really an F-1 and Cart thing, but all cool things must come to an end.. The black w/ polished outside like yours is my favorite .....Cheers!!!
I just bought some new O-Z Superlegarra's in gray for the street (17 x 9) 15.5lbs) and I really like them so far. It gives an RX-7 more of a DTM look if you follow me? I'm a Euro guy at heart and will always have them....
