Outta gas....now it won't start
Old Jul 16, 2002 | 12:21 PM
95R2-89TII Ground Zero's Avatar
Banned
My rx7 was almost out of gas, and while I pulled it out of the garage and down the driveway, it ran out. So I went and got brand new gas for it....2 gallons. Well, I put that in and tried to start it, and there was nothing. It cranks over, but it sounds like it wants to start every once in a while, then it has nothing again....what the hell. Could it be flooded?
Old Jul 16, 2002 | 12:25 PM
GsrSol's Avatar
Z06 powered FD
Don't mean to scare you but my friend ran low on gas in his TII and ended up taking a apex seal with it. I never go below 1/4 tank because of that but hopefully, that's not your case.
Old Jul 16, 2002 | 12:29 PM
Banned
Ouch....that really sucks.....don't tell me that crap. Now I'm really worried.
Old Jul 16, 2002 | 12:40 PM
jr's Avatar
jr
Prime the fuel system as outlined here - http://www.rx7turboturbo.com/robrobi...lease_fuel.htm Then try to start it. Good luck.
Old Jul 16, 2002 | 12:54 PM
error402's Avatar
#!/sup_mod/üb3rg33k
jr - you beat me to it.
Old Jul 16, 2002 | 12:58 PM
Banned
Thanks guys. I appreciate the help.
Old Jul 16, 2002 | 02:26 PM
Flybye's Avatar
It's never fast enough...
This is why I have a fuel pressure gauge
Old Jul 16, 2002 | 02:31 PM
rotorbrain's Avatar
fart on a friends head!!!
mmmmmmmmmmmmmmmm . . . . fuel pressure guage
Old Jul 16, 2002 | 02:50 PM
Banned
Yeah, well I don't yet.....but obviously it would help in this situation wouldn't it? Do you think that priming it will do the trick?
Old Jul 16, 2002 | 03:06 PM
Flybye's Avatar
It could, that's even if fuel is getting to the engine compartment. Since you ran the tank bone dry, you might have picked up excessive dirt that may have been at the bottom of the tank, and that allow could have clogged up the pump and/or the filter.
It's always good to start with the basics, so make sure fuel is getting to the engine first. I'd first remove the hose from the fuel rail, put a big rag over it, and hot wire the pump until you see fuel is spitting out. since you ran it bone dry, it's good to do this first just to make sure the pump and filter are not clogged up.
Old Jul 16, 2002 | 03:09 PM
1bad7's Avatar
running the fuel pump without fuel will fry it
Old Jul 16, 2002 | 03:26 PM
Banned
That's what I thought about doing the other day, but I didn't have the time....so I figured that I would post on forum to see if anyone had a fix, or it had happened before.
Old Jul 16, 2002 | 04:11 PM
1_dollar_83_RX7's Avatar
how many times did you crank the engine when you tried to restart it. Once when I ran out of gas (broken gas guage) i had to recrank it like 10-15 times to get the gas flowing again.
Old Jul 16, 2002 | 04:16 PM
kundo's Avatar
Yeah I remember the first time I ran out of gas, I had to crank the hell out of the car before it started. Then a huge cloud of smoke came out of my muffler then it went away.
Old Jul 16, 2002 | 05:03 PM
alwan16's Avatar
GET MORE GAS! I bet it will start right up after that. there might not be enough gas in the plastic tray that the fuel pump pickup sits in. no gas = no pressure. hopefully it is as simple as that.
Old Jul 16, 2002 | 08:30 PM
Banned
All right here it is. I took the plugs out and the trailing were soaking wet....the leading were just damp. I cranked the engine over a few times and gas vapors came out of the holes that house the plugs. Then I put the plugs in and tried to crank it. The car turned over a few times, but wouldn't start. The battery went dead, so I jumped it, and it still wouldn't start. It feels like it wants to, but it just can't get all the way started. I don't know what it is. I took the fuel delivery line off after the filter and there was gas getting there. As I cranked it....my friend noticed a little white smoke coming from the tail pipe....HELP!!!!!!!!!
Old Jul 16, 2002 | 08:33 PM
Banned
Could it be the ignition pack....I hope not. That thing is tucked way under the intake...not a fun job.
Old Jul 16, 2002 | 08:35 PM
c00lduke's Avatar
have you un flooded it yet? soaked plugs might not start
Old Jul 16, 2002 | 08:44 PM
Banned
Of course. That's what I did when I turned it over with the plugs out and the fuel pump fuse out. Then I dried the plugs and put them back in.
Old Jul 16, 2002 | 11:07 PM
Flybye's Avatar
Once plugs get wet, and after they are dry, they usually won't spark right....
Old Jul 17, 2002 | 12:26 PM
Banned
So what you're saying is that if I get new plugs...and give those a shot...I should be okay....right?
Old Jul 17, 2002 | 01:19 PM
Cheers!'s Avatar
Former Rx7 *****
shoot some intake cleaner or even WD40 on the plugs... let them dry ... stick them in....
but put a bit of motor oil into the housings, resintall plugs... crank over and see if it will start now.
btw filling up the tank to say 1/2 is a good idea to see gaurentee the pump is sucking gas, instead of empty air if it happens the 2 gallons of gas isn't sitting near the pump.
Old Jul 17, 2002 | 01:38 PM
Banned
The problem with getting that much fuel to my car is the fact that it doesn't drive, so its hard for me to transport it....LOL
Old Jul 17, 2002 | 02:36 PM
OptusX4's Avatar
Anyone thought of carbon lock yet? He only rolled it out of the driveway... I've heard that cold start + short distance + cold stop (can)= carbon lock... Just a thought, and something to check.
Adam
edit: here's some info http://mrmazda.members.atlantic.net/...t.html#CLOCKED
Old Jul 17, 2002 | 02:45 PM
Banned
Adam
It doesn't have carbon lock, cause it turns over, it just won't start all the way. I think it may be the ignition, but the only thing that makes me think no is that the car ran for about 2 seconds before it shut off and won't start again.
