Microtech Microtech lt10s starting issue
Old Aug 29, 2011 | 10:20 AM
MazdaMan87's Avatar
I have an S5 TII with 750cc secondaries, stock turbo, arc top mount and I have a microtech lt10s with the x4 ignition, my car gets right to where its about to start, but then just keps turning over. I currently have silverrotor's TII map in my car and I feel like im at a dead end, any ideas?
Old Aug 29, 2011 | 11:37 AM
Sammy Built's Avatar
501 WHP Club
Upload some snap shots off your program. Have you recently rebuild or done a compression test?
Old Aug 29, 2011 | 12:26 PM
MazdaMan87's Avatar
idk how to uplad photos, and compression is good according to pettit racing
Old Aug 29, 2011 | 12:27 PM
MazdaMan87's Avatar
it was rebuilt before I got it**
Old Aug 29, 2011 | 12:59 PM
501 WHP Club
Was the car running before with the program from silverrotor you said that you upgraded your secondaries but still should not cause it to not start. Make sure your map sensor is fitted correctly then check your calibration on your Tps if all is good pull your plug s out lmk what you see...
Old Aug 29, 2011 | 01:03 PM
MazdaMan87's Avatar
I tried to calibrate the tps and I couldnt figure it out at all, I have to be explained to like a 5year old when it comes to electronics. hahaha
Old Aug 29, 2011 | 01:21 PM
MazdaMan87's Avatar
I removed the leading and trailing plugs on the rear rotor and the leading was dry but the trailing was wet
Old Aug 29, 2011 | 01:47 PM
MazdaMan87's Avatar
^^ same goes for the front rotor as well
Old Aug 29, 2011 | 02:16 PM
MazdaMan87's Avatar
map sensor fitted correctly you mean the vacuume line going fromt the intake manifold to the microtech?
Old Aug 30, 2011 | 10:35 AM
501 WHP Club
OK vacumn line is fitted so check. Trailing plugs wet so you definatelly getting fuel as leading that works as a wastespark so that's ok. Now for the tps that needs to be calibrated for the car to start on smoothly. So I'm going to pm your number and just text me and ill tell you exactly how to calibrate but you need a hand controller or laptop with a single.
Old Aug 30, 2011 | 10:37 AM
501 WHP Club
I mean dongle
Old Aug 30, 2011 | 12:45 PM
MazdaMan87's Avatar
alright sweet, thanks a lot! when we speak on the phone, there are a few updates on the car I want to make you aware of as well.
Old Aug 30, 2011 | 07:09 PM
MazdaMan87's Avatar
ok well idk what the hell I did, but it runs and starts just fine, its hard to get started but it starts, the real text will be tomorrow when the engine cools down.
Microtech
30
Apr 23, 2016 06:37 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
FB_Frank85
Aug 31, 2015 03:31 AM
befarrer
Aug 14, 2015 04:18 PM
