Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D moding the dizzy?
Old Aug 25, 2011 | 08:15 AM
are-ex's Avatar
Brewster
moding the dizzy?
hey guys i have a v4 wolf and the guy i bought it off said i would need to mod the dizzy in order to get it working, is this true and what other things do i need to change, eg coils? thanks guys
Old Oct 1, 2011 | 10:00 PM
s1rx's Avatar
rotary powered
providing your ecu is v4 - 2 options: you can modify the CAS or you can adjust the ignition syn/ref on the software using the factory CAS.
search.there should be info on doing this on here and there is also a dealer tech writeup on the wolfems website explaining settings. I had my s4 6 port setup like this worked fine.
Note: you will need to zero the timing on the wolf and have the factory base map to get the engine to fire also.
24seven_dada
20
Nov 10, 2018 12:03 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
