header + cat delete with stock catback?
Bone stock 83 GS. Stock air box (or whatever that contraption over the exhaust ports is called) has a pretty nasty leak, engine bay gets hot, smells bad, etc.. doesn't overheat though.
Is there a header out there that if I get a cat delete pipe will work with the rest of the system to the stock muffler? What kind of power gain can I expect from this?
air cleaner, the thing on top of the carb is an air cleaner.
the RB header + presilencer bolts to the stock connecting pipe + muffler. or cat back if you prefer. 10-12hp gain. the stock muffler is ok, but it gets a little tinny/raspy.
I don't recommend using the stock muffler with a header, even with a presilencer. It sounds loud and bad.
If you can do your own fab work with thick-walled pipe (I can't stress enough how important that part is) and make a proper merge collector, there's not much difference between the two. The main problem with the collected header is that it collects to 2" (the FB version does, anyway), which is too small to make any real power. But if you're using a stock muffler, that's a moot point.
I've no welding experience, only a little soldering...
I want something that gives me a little edge now for DD that won't need re-upgrading when this becomes a track car... without breaking the bank.
msilvia
28
Apr 14, 2016 12:58 PM
