Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
JZ swap parts list.
Old Aug 21, 2011 | 06:30 PM
sa22c[est. 1979]'s Avatar
Resident N00b
OR JZ swap parts list.
Okay, I'm going to be doing this swap in exactly two months from todays date into my vert. I'm just looking for a little bit of information on a list of items, both recommended an required for the swap. Unfortunately, a lot of the swaps I've seen aren't that well documented, and I want to go into it with as much info as possible. Aside from mounts, engine, trans,drivshaft, and wiring, what else am I going to need to modify/buy? Keep in mind, I'll be using the Tech2 kit, as I don't have to the time or resources to fab my own mounts and such. Also, is anyone running the stock twins, and electronics? Or is it a must to switch to a single, and a standalone? Thanks in advance for any help guys.
Old Aug 22, 2011 | 10:12 AM
CKxx's Avatar
You can leave the stock twins and ECU if you want, but I believe a lot of people like to simplify the motor as they do the swap. When you go removing half the OE parts from the engine, the stock ECU doesn't take kindly to it, necessitating some sort of new engine management. Also, the stock twins weigh roughly...1 billion tons.
What type of motor do you have, and from what vehicle?
Old Aug 22, 2011 | 04:45 PM
jakkyl's Avatar
subscribed. I plan on doing this swap also once the 13b kicks the bucket.
Old Aug 22, 2011 | 04:47 PM
jakkyl's Avatar
please delete
Azevedo
26
Mar 1, 2019 09:19 PM
