Today's work on the mazda
Old Aug 19, 2011 | 07:52 PM
murben's Avatar
NY Today's work on the mazda
Finally got around to cleaning up my engine bay... really regretting not taking some before pictures. The car had 25 years of grease and grime all over the inside of the engine bay and on the motor. Still have a little more work to do but I think it's looking pretty good, especially being that it's all original paint that was just covered up by grease. Also installed the new aluminum radiator and silicone hoses. What do you think?
Attached Thumbnails Today's work on the mazda-img_1953.jpg   Today's work on the mazda-img_1954.jpg
Old Aug 19, 2011 | 09:06 PM
j9fd3s's Avatar
Community Builder
looks great!
Old Aug 19, 2011 | 09:40 PM
acekid7's Avatar
Rotory United RU.
nice and clean. she will drive better now
Old Aug 19, 2011 | 10:44 PM
Lotus000's Avatar
Nice work cleaning that thing up. I like the color too, same as the original color on mine
Old Aug 20, 2011 | 08:29 AM
ztfdrake61's Avatar
In Love with a GS
Creative idea on the battery hold down
Old Aug 20, 2011 | 11:22 AM
murben's Avatar
Ha ha... yeah, gotta do something about that. When I got the car the previous owner just had the battery sitting there loose, flopping all over the place. That ratchet strap was the quickest thing I could in the garage to strap it down. Gotta re-visit that sometime....
Old Aug 20, 2011 | 11:25 AM
ztfdrake61's Avatar
In Love with a GS
no worries, i ran it for 2 years without anything holding my battery down, i've checked into getting replacements, but black dragon is way overpriced for those pieces
Old Aug 20, 2011 | 11:30 AM
85Gen1's Avatar
looks really good clean, now the challange is to keep it that way!
Old Aug 21, 2011 | 03:19 AM
7aull's Avatar
RX HVN
would have been sweet to have re-sprayed the rad support panels when swapping the rad...
still doable if you pull one at a time. New painted parts always pump the Bling-factor.
I started doing what you did too and ended up with most of the hardware pulled from the engine bay before I was happy. laid up the car for 2 weeks...
no self-control.
Does make it run better tho, as suggested by others!
Stu Aull
80GS
Alaska
Old Aug 21, 2011 | 09:34 AM
snivley whiplash's Avatar
brappppp brappppp
found a cool battery hold down. made by Whaler boats, has a bottom tray two long bolts a top ring and thumb turn screws. Just dropped the bottom tray in place, drilled and mounted with number 14 sheet metal screws. dropped the battery back in and mounted it. had to cut down the long bolts the clear the hood but works awesome and is very solid. very heavy duty as it was made for a marine application
Old Aug 21, 2011 | 10:45 AM
Denser's Avatar
so clean!! im gonna clean my engine bay right now 8]
Old Aug 21, 2011 | 02:20 PM
murben's Avatar
was it something like this that you used for the battery?
http://www.iboats.com/Battery-Hold-D...-view_id.38670
Old Aug 23, 2011 | 04:19 PM
Carl's Avatar
I use a Miata battery, since it is 50-70% of the weight of a stock size. Plenty of starting power. It fits in a U1 plastic battery box bolted through the bottom to the stock battery support. Nice and clean and simple. The box cost $10-$12. I'm not sure if a standard battery with a box would work. Might be too big.
Carl
Old Aug 23, 2011 | 07:00 PM
notveryhappyjack's Avatar
1 bar boost
OP
what radiator you using ? looks like a nice aluminum piece
Old Aug 24, 2011 | 07:23 AM
murben's Avatar
It's an American Eagle radiator. Got it off of e-bay for $185 shipped. Quality seems to be really good, has all of the ports for the sensors to screw into. They said it was an exact fit, but it was really a hair bigger than stock and took a little bit of manipulating to get into place, but wasn't bad at all.
astrum
24
Nov 15, 2017 08:44 AM
plentymoon
NW RX-7 Forum
Sep 5, 2015 08:55 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
