non consistant boost pattern?
Old Jul 16, 2002 | 12:22 AM
trigeek37's Avatar
it seems that I get a different boost pattern depending on gear, and current driving style eg accelerating hard from 1 on, mashing throttle in 4th at highway speeds etc. is this normal? I just installed my boost gauge this weekend, so this is all new to me.
Old Jul 16, 2002 | 12:40 AM
RICKRX7's Avatar
Yes that is normal. Now that you have a boost gauge,you should do the 3rd gear acceleration test.
Old Jul 16, 2002 | 12:46 AM
trigeek37's Avatar
and that is?
yes, I am still a newbie!!!!
btw, gunna get on the dyno this week.. I am concerned about running lean....
Old Jul 16, 2002 | 01:05 AM
Swamp RX-7's Avatar
Drive the car to 30mph in 3rd gear. Then go to WOT, you should read 10psi at around 2800-3000rpms, @ 4500rpms there should be a slight dip to 8psi with an instant jump to 10psi when the second turbo kicks in.
Old Jul 16, 2002 | 01:06 AM
Swamp RX-7's Avatar
What kind of mods are you running?
Old Jul 16, 2002 | 01:07 AM
RICKRX7's Avatar
I do no remember the details. you will have to do a search. You will be able to see if your FD is up to speed and you are boosting properly.
Dyno? have you added some mods? You might want to wait on the test.It requires you to WOT through 3rd gear.
Old Jul 16, 2002 | 01:39 AM
trigeek37's Avatar
my mods so far:
RB cat back
PFS DP
PFS SMIC
PFS cold air
PFS pigy ECU (the one with 1 2 3 settings)
efini y-pipe
alum ast
blitz boost & water temp gauges
rgordon1979
40
Mar 15, 2022 12:04 PM
toplessFC3Sman
Mar 20, 2018 01:54 PM
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
