The AC unit in front of the rad. can I run W/O
Old Jul 15, 2002 | 09:53 PM
From: Minnesota, now in FL and I dont think I'm goin back
OK I put in new FMIC and radiator, but I screwed up and the AC unit ( not the lines the actual radiator looking thing ) that sits in between the rad. and the FMIC. Anyways I have to get it welded to use it again, my question is can I drive my car W/O it hooked up so I can take it somewhere to get welded. I dont care about not having AC I never use it anyways. So can I drive my car?
Thanks
Old Jul 15, 2002 | 10:06 PM
amp's Avatar
amp
old yella
your referring to the condenser...
u can drive your car without it but would suggest to cap the open lines temporarily...
assuming that you vented to atmosphere when you initially removed the condenser (illegal for environmental reasons) youll need to refill it....
Old Jul 15, 2002 | 10:37 PM
so i can drive with it off till I get my condenser refilled an welded.
Mike
Old Jul 15, 2002 | 10:49 PM
amp's Avatar
amp
old yella
Mike
you can drive with it off indefinitely....till u get your condenser reinstalled and filled...if youve contemplated on complete removal due to rare use...it has its advantages..weight reduction although not substantial..more volume of air flow in the area.....maybe not with the FMIC...use of the ac switch as a fan mod..
immanuel__7
89
Sep 5, 2015 10:23 AM
