New engine for the FB!
Old Aug 13, 2011 | 03:54 PM
Itsdaveonline's Avatar
So the 12a still had some life at 235,000 MI, but it was leaking badly and not performing like it used too. So now the FB is being overhauled...Engine is going to be a fresh 13B built by rotor sports racing.
Powerplant upgrades include:
-rebuilt / new 4 port 13B....
-high pressure seals all the way around
-streetport
-Racing beat streetport intake system
-Holley carb
-mallory fuel pump
-mallort fuel pressure reg
-Racing Beat headers, catback
Other upgrades
-new steering gearbox
-tranny rebuild
-exedy clutch
-KYB struts
Most of these upgrades are done, but still waiting for a 13b k-member since the engine will not mount to the existing one due to a different bolt pattern. Also anticipate issues with the stock 12a radiator. Still anticipating 190~HP
Old Aug 13, 2011 | 05:21 PM
Jibaro 12A's Avatar
searching...
What seals are you going to be using?
Old Aug 13, 2011 | 05:29 PM
rx71king's Avatar
the diabolical one
nice.. nice..i see that you are a rotary nut too....
Old Aug 13, 2011 | 05:56 PM
Don't know about all the seals, but I believe it has conventional 2-piece 3mm apex seals along with corner seal springs from a 93. O-rings gaskets and other engine stuff is probably upgraded or from other generations too... It shall be dubbed the Frankenstein engine!
Old Aug 13, 2011 | 07:06 PM
Jibaro 12A's Avatar
searching...
goodluck. Im involved in a similar project at the moment
Old Aug 14, 2011 | 04:23 PM
orion84gsl's Avatar
My 7 is my girlfriend.
I've got a similar setup with a Sterling carb. Still needs dyno tuning but it goes a lot better than the 12A. 190 might be a high goal. It can be done, but it will take a lot of tweaking, both with the tuning and the exhaust. Everything has to be pretty much perfect. I like the super clean engine and trans. Will make the engine bay easy to show off.
Old Aug 14, 2011 | 05:46 PM
twinkletoes's Avatar
So fresh and so clean!! I see a turbo piston manifold in the background!!
Old Aug 14, 2011 | 08:28 PM
rx71king's Avatar
the diabolical one
looks like a 3rotor manifold....
Old Aug 14, 2011 | 08:51 PM
Jeff20B's Avatar
Lapping = Fapping
Yeah, looks like.
Old Aug 14, 2011 | 09:07 PM
Starfox07's Avatar
Environmentally-Hostile
Def a 20b manifold.
The 13b looks very pretty.
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
