compression fittings
Old Aug 12, 2011 | 07:15 AM
cshaw07's Avatar
I need a cheaper hobby...
has anyone used aluminum compression fittings on aluminum fuel line? my fuel pump puts out 175gpm and is 80psi. will these work fine, or will they **** fuel the second i start the car lol
Old Aug 12, 2011 | 10:12 AM
Brent Dalton's Avatar
Sua Sponte
I've been using them on my car with the russell aluminum fuel line for over a year without an issue.
Old Aug 13, 2011 | 02:09 PM
cshaw07's Avatar
How many psi is your pump? That's exactly the answer o was looking for!
Old Aug 13, 2011 | 04:22 PM
Sua Sponte
Off the top of my head, I don't remember. It's rated for around 650hp though. Rail fuel pressure on mine at idle is 58psi I believe, but I'm LS1.
Old Aug 13, 2011 | 11:10 PM
cshaw07's Avatar
Perfect. That's great news! I can rest a little easier. Did you crank them down as hard as you could or just pretty tight?
Old Aug 14, 2011 | 01:26 PM
Syritis's Avatar
my pump is 135gph and 95psi max and i've had no issues in the years they've been installed. there is a specific torque for them but you'll feel it pretty easy when it abruptly requires more force to tighten.
Old Aug 14, 2011 | 08:23 PM
nofords's Avatar
Mr. September FB 2011
Summit aluminum line and compression fittings here.
I run 60psi on my dual 380lph pumps. No issues for 2 years.
Old Aug 15, 2011 | 12:41 PM
BLUE TII's Avatar
Rotary Motoring
Just be very careful how you use the aluminum fuel line as any repeated whip, flex or vibration will work harden the tube and cause it to crack.
Long sections should have multiple clamps to the body and clamped close to the ends. Use full swivel fittings with a loop in the flexible hose section so the hose moves easily and does not transmit any force to the aluminum line.
ZacMan
Sep 19, 2015 09:20 PM
mulcryant
Sep 9, 2015 05:24 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
