best way to drain a GSL-SE fuel tank?
what is best way to drain a GSL-SE fuel tank?
I gotta drain fuel, was planning on unplugging the fuel filter and letting the fuel drip out the hose, any tips or faster/better ways to drain the fuel?
pop the left rear interior panel and reach in you will find the gas door release solinoid lever just move it and the door will pop. tank should have a drain plug in the forward section somewhere, center I think. been a while.
Trending Topics
You should have a drain plug. Cant miss it on the bottom of the tank if you do.
If not just connect the fuel pump to positive and negative with the outlet fuel hose in a large bucket. Then just watch it flow!! I did this and worked like a charm. Just dont cause any sparks
I put the old fuel in my daily driver hahaha
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
