Name that part....
Old Jul 15, 2002 | 03:32 PM
Taranis's Avatar
Name that part....
Quick question:
There's a sensor on the radiator, driver's side at the bottom that has a busted connector. I wanna call it the water temp thermo sensor.
I don't have my manual handy (I'm at work). What the heck is that thing called in the book?
Thanx
JB
Old Jul 15, 2002 | 03:46 PM
HAILERS's Avatar
HAILERS
Water temperature switch. See page 4B-46 of the fsm. Called the same thing whether turbo or n/a. Used for emissions. Helps determine when the Relief solenoid is activated/deactivated. Not to be confused with the temp sw for the gauge on the dash. I think its only on 86-88 cars.
Old Jul 15, 2002 | 03:47 PM
UniqueTII's Avatar
Slow and old
What does that do? What does the temp sensor on the water pump do? I thought one was for the e-fan and one was for the gauge, but I am not sure.
Old Jul 15, 2002 | 03:54 PM
HAILERS's Avatar
HAILERS
Water thermo sensor is on the back of the water pump. Its used for the ECU in computing fuel usage. On my 87 there is also a switch on top of the water filler neck thats used for the electric fan. I edited the first reply for a description of the one on the radiator. If you pull that ones plug(s) off, you will have your acv relieving overboard all the time instead of pumping air to the exaust ports at idle.
Old Jul 15, 2002 | 03:56 PM
UniqueTII's Avatar
Slow and old
So there was one more I didn't even know about...thanks.
deftones1868
The Bad & Fugly Members
Apr 20, 2013 07:28 PM
80's old school
1st Gen General Discussion
33
Sep 13, 2010 11:16 AM
DC 91 fc3s
West RX-7 Forum
Aug 24, 2010 05:25 AM
Bobbo
Jun 9, 2010 10:37 PM
