E-Fan question
Old Aug 1, 2011 | 09:56 AM
DarkDrakeX's Avatar
RX-7 NUT
E-Fan question
I searched and couldn't find anything.. Prolly searching for the wrong thing but i was thinking about buying a E-Fan kit off amazon.
http://www.amazon.com/PROCOMP-ELECTR...YE/ref=lh_ni_t
Its 4000CFM will that be enough?? I currently live in the Mojave desert of California so it gets extremely hot here.
Sorry for the dumb question.. thanks in advance
Old Aug 1, 2011 | 10:06 AM
t_g_farrell's Avatar
Waffles - hmmm good
Search seemed to work fine for me:
Try a little harder next time
Its lot cheaper to go to the JY and get something that works for a lot less. You need
at least 2000 CFM I think to be safe.
Old Aug 1, 2011 | 10:35 AM
rxtasy3's Avatar
u have too many tabs open there tim. but i agree, just get one from a junkyard. many use ford taurus fans. got mine off a 93 mitsubishi galant. either way, u'll have to come up with a way to mount it to the rad.
Old Aug 1, 2011 | 10:41 AM
Directfreak's Avatar
I am a Jeeper Now.
4000 CFM would be enough, but that kit is only 2000 CFM.
Also I would look for something with a shroud.
Makes it much more efficient.
Old Aug 1, 2011 | 11:01 AM
84stock's Avatar
Get a 3.8l Taurus fan, wire low speed on constant and wire the high speed to a thermostatic switch. The fan shrowd will need a little trimming. It works awesome for me.
Old Aug 1, 2011 | 02:38 PM
DarkDrakeX's Avatar
RX-7 NUT
Cool thanks alot guys.
Old Aug 2, 2011 | 06:12 PM
CobraStngSVT's Avatar
Team SR
x2, definitely get one with a shroud... works waaaay more efficiently.
Old Aug 2, 2011 | 07:30 PM
Maguire's Avatar
Born 2 Brap
2nd the Taurus fan
Old Aug 3, 2011 | 03:09 AM
Mr_Miles's Avatar
you can wire the low speed constant with the high speed on a switch? dang, wish i knew that, I'd have wired the HS already!
Old Aug 9, 2011 | 04:01 PM
ColinR's Avatar
AB Tarus E-fan
Any particular year of Taurus?
Old Aug 9, 2011 | 04:41 PM
RX-7 Chris's Avatar
If I remember right it is '93-'95
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
