Super AFC Area is for discussing the Apexi Super AFC
Super AFC safc or rtek
Old Jul 28, 2011 | 04:41 AM
dakota's rx7's Avatar
IN safc or rtek
what should i do on my 87 tII 34xxx miles on rebuild looking to make more hp. i have boost gauge aem afr gauge. what is the advantage of rtek and safc and the disadvantages of them both. i need to decide befor i start putting on my other parts. greddy 3 in exhuast going to port turbo waste gate. i need bigger injectors for the car ill buy them next week what else should i do? should i go safc or rtek
Old Aug 23, 2011 | 07:37 AM
bump
Old Sep 1, 2011 | 12:58 PM
im planning on running over 8 psi of boost so is the rtek 1.7 ok to run at this rate or should i just go safc and tune it that way
Old Sep 15, 2011 | 12:09 AM
suck_my_rotor's Avatar
*Currahee Performance*
rtek 1.7, a wideband, and an safc is a pretty decent setup. the next level would be a standalone lol. but do both, its a good combination.
Old Sep 22, 2011 | 12:56 PM
going rtek 1.7 with safc and a wideband hope this idea is an ok one. i have an aftermarket turbo with 3 inch down pipe what size injectors should i get i have a set of 720s
Old Oct 7, 2011 | 05:17 AM
well ended up geting an rtek 2.1
Old Feb 6, 2012 | 04:50 AM
shocker003's Avatar
bump
rtek 2.1 vs rtek 1.x and apexi safc
as far as tuning goes, what would be best?
Old Apr 10, 2012 | 07:35 AM
PortedRotorTuner's Avatar
Gap Slayer!
How is that working out for you?
I'm on the same decision right now.
Old Apr 10, 2012 | 09:37 AM
go stand alone you will never look back and worth the money
Old Apr 10, 2012 | 09:53 AM
Gap Slayer!
per the rules I'm not allowed to go stand alone. Well I could but then I would have
to go up a class. I'm staying in the stock class. My only mod will be the
RB Rev II exhaust. Engine is stock. Just rebuilt with all new housings and plates.
I was just going to go with the rtech 1.5. I have no way to control boost
so I was just looking at my best bet for fuel control. With in the rules I can
also use an SAFC. But I like the idea of the rtech 2.1 better which is also within
the rules because it stays in the stock ECU housing and uses the stock ECU
hardware. If I could go stand alone I would.
Or were you refuring to the rtech 2.1?
I kind of consider it a little bit different then a full stand alone replacement ECU.
But not far from it.
Last edited by PortedRotorTuner; Apr 10, 2012 at 10:05 AM. Reason: maybe misunderstood
Old Apr 10, 2012 | 11:21 AM
i would go with the rtek 2.1 because later on if you want to add more upgrades you can have control over timing.
WyomingTII
Rtek Forum
Oct 26, 2015 05:26 PM
lnlreaper
Sep 27, 2015 09:59 AM
