Safc
Old Jul 15, 2002 | 03:25 AM
twinturboy's Avatar
Safc
I was wondering if anyone has successfully used an apex Safc with a 3rd gen. My current mods are intake, dp, mp, cb, non sequential turbos, pettit ecu, profec b. The car runs very well putting down 299.5hp at 12lbs, but I was wondering if I could add a Safc to adjust the fuel a little to get it perfectly tuned. I've heard that using it with the stock ecu will cause it to hit fuel cut at higher than stock boost levels, but since I have the pettit ecu this shouldnt be a problem, correct? I know the best thing to do would be to get a power fc or something similar, but for $200 for a used Safc fits into my budget a lot better. Is there any reason that the Safc doesnt work with the 3rd gen, such as the oil injection at certian loads, or the 2 injector stages? Any info would be appreciated. Thanks.
ANEEL
93 touring
orlando,fl
Old Jul 15, 2002 | 05:32 AM
skunks's Avatar
I'm a CF and poop smith
Personnaly I use a SuperAFC on my FD and it works great for me, it's really easy to adjust my A/F ratio relibly which I have done on a Dyno (no seat of my pants dyno tuning here!). If you are willing to sacarifice your pettit ecu, it might be easier/better/cheaper to get a PowerFC but if you can get a SuperAFC for cheap (i have seen them going for $150 used), I would so go for it.
Good luck
Old Jul 15, 2002 | 07:00 AM
jspecracer7's Avatar
1JZ powered
Good luck
I used it in my TII and it worked great! I've also seen them used in FD's and they work great! It's more of a band-aid until you can get a stand-alone, but it's one hell of a band-aid
Old Jul 15, 2002 | 10:20 PM
skunks's Avatar
its also a great data logger so that you can quickly find out how much you reved to and what your max boost and other stuff like that is.
SaabGuy
19
Feb 4, 2004 08:25 PM
rx7_88turbo2
May 25, 2002 07:18 PM
SaabGuy
Apr 21, 2002 07:16 AM
crossbar17
11
Apr 1, 2002 09:20 AM
