Intake manifold is fucked.
Old Jul 15, 2002 | 03:10 AM
Powridah's Avatar
Ok this afternoon i was sayin to myself that I am gonna put in my new OMP lines. didnt look that difficult. so i go at it, so many god damn vacum lines and **** to unhook so i took off the intake manifold and noticed there was a gasket. ****. So i said bah it should be ok. so i tighend all the bolts up and i snapped the one that is sort of in the middle its like 3-4 inches long grrr. so i still thought oh it will be ok. well i hooked everything back up and looked at a electrical connector coming out of the BAC... thought to myself what the hell ? wasent it connected to somthing before ? . The car started up fine no problem and drove decent. i started flooring it later tonight and it sounds like all the air is escaping and the car isnt very fast, and when i accelerate with no boost slowly the car wont go past 5 and hesitates. so im thinking its that damn gasket and its probobly not cheap ! so im asking... that bolt that I broke. isnt it making that much of a difference ? do I need a new gasket ? can I just use liquid gasket stuff and put it over the old one ? and is this even casuing my problem ?
Old Jul 15, 2002 | 03:25 AM
The Ace's Avatar
Greek Power
Wait a sec: you have minus one gasket (the intake manifold's, no less), and minus one sturdy bolt, and you're asking if this is a problem ?
Old Jul 15, 2002 | 09:42 AM
Silkworm's Avatar
Has been.. hangin' around
How tight did you tighten that bolt if you managed to snap it??????????? It's only supposed to be torqued down to 40 ft/lbs IIRC..
PaulC
Old Jul 15, 2002 | 10:10 AM
jspecracer7's Avatar
1JZ powered
I think he wants us to console him...
YES, it is the bolt you broke AND the lack of a gasket that is causing you not to have boost.
Old Jul 15, 2002 | 10:51 AM
Wankel7's Avatar
Haven't we ALL heard this
Not sure what year it is. But on my Turbo II (91) I believe the torque was about 21 ft lbs. Might want to double check that one.
James
Old Jul 15, 2002 | 11:15 AM
rico05's Avatar
WTB S5 N/A FC
No gasket + snapped bolt = No seal on manifold
No Seal On Manifold + vaccuum created by intake of air = leak
Leak = No power
rgordon1979
40
Mar 15, 2022 12:04 PM
armans
Sep 6, 2015 09:02 PM
