Will these wheels fit?
Old Jul 16, 2011 | 11:28 PM
acekid7's Avatar
Rotory United RU.
Car= GSLSE
Wheel= 16x7
offset =0
Will this fit with out rubbing. I found some sexy meshies that i want to get. Oh And the car has been dropped one inch.
Trust me Ive searched but i cant get a straight answer
Thanks for the help guys.
Old Jul 16, 2011 | 11:31 PM
BUMBLEBEE7's Avatar
JETFUEL
Bolt pattern on the new wheels?
Old Jul 16, 2011 | 11:55 PM
che'srx-7's Avatar
0 offset is agressive as hell for the FB body,
Old Jul 16, 2011 | 11:56 PM
acekid7's Avatar
Rotory United RU.
4x114.3. I'm sure its the correct bolt pattern I just want to know if they are gonna rub any where.
Old Jul 17, 2011 | 11:20 AM
broncoblitz's Avatar
It will rub everywhere. You'll have to have adjustable camber in the front, and roll the front fenders to fit. The rear you might be able to fit with rolling and pulling the fenders a bit depending on tire size.
Old Jul 17, 2011 | 11:24 AM
For reference my gsl-se has 16x7 +10 with 195/45/16 in the front. 16x8 +0 with a 215/40/16 in the rear and the rear needs fender flares because they stick out an inch beyond the fender. THe front was easily brought into line with a little bit of camber.
Old Jul 17, 2011 | 10:42 PM
acekid7's Avatar
Rotory United RU.
wow beautiful car man. By looking at that i dont think 16x7 with 0 offset will fit. I mean if your front is +10 and you have to use camber to keep em in i don't think it will work.
Old Jul 17, 2011 | 11:03 PM
Mr_Miles's Avatar
Those are hot.
Old Jul 18, 2011 | 10:47 AM
If you have camber plates, the front with a +0 offset shouldn't be too bad. I'm running about -2 degrees negative camber, so nothing to crazy to get them to fit and I haven't even rolled the fenders yet.
The rear will be trickier but you may be able to get by with rolling and pulling the rear fenders a bit to get them to fit.
Old Jul 18, 2011 | 03:30 PM
acekid7's Avatar
Rotory United RU.
thanks but i dont want to touch the fenders at all just in case if i want to go back to stock. Also isnt there a risk of cracking the paint when u roll the fenders.
Old Jul 18, 2011 | 03:42 PM
RX-Slevin's Avatar
Try to keep the backspace at maximum 4.25" or 4.5" so it clears everything. .. Those rims look sick BroncoBlitz
Old Jul 18, 2011 | 10:50 PM
acekid7's Avatar
Rotory United RU.
thanks ill keep that in mind. I do have to say again those wheels are sexay.
fidelity101
13
Aug 31, 2015 07:47 PM
