Megasquirt No PW1=no fuel at cranking car
Old Jul 16, 2011 | 03:07 PM
Gokou104's Avatar
Racing since u wre little
I install a MS1 V3.0 on my rx7 bridgeport car and I'm having problems at start as is not activating the injector everything is been check several times thinking is wire problems but are none. I'm using the original setup that Aaron have on his website but nothing the car won't start. Plenty of spark but no fuel what so ever. I'm running MS1 extra have a zeal daughter board install, 550cc in primary and secondary's. Can somebody tell me what can be wrong or have a file with better set up to have the car start. Like I said I have exactly the same set up from Aaron's website, and as I'm not good posting pictures of the setting from Megatune I can't show you what I have, I search on the forum for 2 days and can not find anything.
Old Jul 16, 2011 | 03:20 PM
Gokou104's Avatar
Let's c if this work.
Old Jul 16, 2011 | 06:31 PM
black_sunshine's Avatar
Okay, I'm no expert here, but here's some thoughts:
You've flashed it with the latest firmware, right? I didn't think Megatune worked with the latest firmware, but I can't say I really tried since I've always used TunerStudio. If you're running the stock FW, that is your problem.
Make sure to set up the cranking PWM for the injectors as well as the IAC.
Everything SHOULD start with Aaron's base maps, with 550cc injectors.
You've got spark, so the computer is seeing RPM (VR1). Make sure it's firing both the leading and trailing, as the trailing run the car most of the time. It's my (and I may be incorrect) understanding that VR1 operates the leading coil, and VR1 + VR2 operate the trailing channels A & B and the injectors.
Hope it helps!
Old Jul 16, 2011 | 09:45 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
we got it to start, but it immediately dies
juan, now that i think about it, check your fuel pump wiring. I think the fuel pump is turning on when we crank it, but for some reason is turning off after it starts. try wiring it to always be on and see if it stays running
Old Jul 16, 2011 | 10:10 PM
Gokou104's Avatar
Yes I have the latest firmware. We have start the car but it just stay on for 5 sec and cut off. any ideas?????
Old Jul 16, 2011 | 10:13 PM
Gokou104's Avatar
Jamin,
I will check that tomorrow and see. I don't think it is the problem but at this moment anything can be....
Old Jul 16, 2011 | 11:11 PM
papiogxl's Avatar
What's the point??
What does your warmup enrich look like? My HBP wants a ton of fuel when cold- 240% enrichment at 80, 225 at 100 and 195 at 130. And even at 240%, its still lean and wants to die.
Old Jul 17, 2011 | 10:02 AM
Aaron Cake's Avatar
Engine, Not Motor
You likely need more fuel. On a set of 550CC injectors, you'll probably need ~4mS to idle the car, and around 7-8mS when the car is cold. If it starts then stalls, it needs more fuel.
Old Jul 18, 2011 | 12:47 PM
Gokou104's Avatar
Hey you are saying that you have a bridgeport and it need a ton of fuel I'm new to this megasquirt do you have a picture of your VE1, and a picture of what you post?
Thanks for helping me out...
Old Jul 18, 2011 | 12:49 PM
Gokou104's Avatar
Aaron Where exactly you do that??? I'm not that expert with this thing.....
Old Jul 18, 2011 | 06:15 PM
Gokou104's Avatar
Warm up Wizard, Mine looks like this:
-40C - 195
-29C - 195
-18C - 195
-7C - 195
4C - 180
16C - 165
27C - 155
38C - 145
54C - 132
100C - 100
Is not negative #
Old Jul 18, 2011 | 08:00 PM
Gokou104's Avatar
If require more fuel on the VE1 the number increase or decrease???
Old Jul 20, 2011 | 10:21 PM
gxl90rx7's Avatar
we got it to idle today for several minutes. but starting it is a pain! it hardly pulls any vacuum at idle. any tips for cranking settings? it seemed to help changing crank rpm from 200 to 1000
Old Jul 21, 2011 | 01:49 AM
papiogxl's Avatar
What's the point??
More fuel is a bigger number. This is my *rather rough* VE table. Note this is 9.4:1 S5 T2 HBP motor with S5 T2 I/Ms and 550cc injectors running NA currently. For some reason, my req_fuel is set to 10.5, so the VE will vary slightly. Map runs pretty rich all throughout on my engine. Ignition map is BDC's work for HBP's.
Crank RPM shouldn't be set nearly that high. It'll go into crank mode if you drop below 1000 RPM then. I have good luck at 400 RPM. I also remember seeing a post by muythai that mentioned some issues with time based cranking timing, so I have mine set to trigger return.
Also, try running the settings I have for the warmup wizard and see if it will run while cold on its own. What kind of vacuum is it pulling at idle? Mine at a 1500 RPM high idle pulls ~60 kPa and at 1000 RPM, it sits about 75 kPa
Old Jul 21, 2011 | 07:40 AM
gxl90rx7's Avatar
it idles at 2000 right now, the vacuum is only around 20kpa
Old Jul 21, 2011 | 01:10 PM
papiogxl's Avatar
What's the point??
I go by absolute pressure, so 20 kPa of vacuum is 80 kPa absolute. Try advancing timing at idle more, and it should start pulling more vacuum.
Old Jul 21, 2011 | 03:46 PM
Gokou104's Avatar
I will try that..
Old Jul 21, 2011 | 04:51 PM
Gokou104's Avatar
Mike How you got it to trigger return???
Old Jul 21, 2011 | 06:54 PM
papiogxl's Avatar
What's the point??
-Spark
-spark settings
-cranking timing
-drop down menu -trigger return
Old Jul 27, 2011 | 12:35 PM
Gokou104's Avatar
Well a update with the MS1 is that the car still start and stalls no success on trying to get it idle yet we are trying different fuel, spark and anything to get it right. I will keep posting if any success.....
Old Aug 24, 2011 | 08:06 PM
Gokou104's Avatar
Well still no success with the Idle of the car I don't know what else to do......
Old Aug 27, 2011 | 10:13 AM
Aaron Cake's Avatar
Engine, Not Motor
Post an MSQ.
I almost guarantee it just needs more warmup enrichment, more afterstart, and more fuel in general.
Do you have any way to monitor AFRs?
Bridgeports take a LOT OF FUEL to start, warmup and idle. I figure it costs me 50 cents every time I start and warmup my car.
Old Aug 27, 2011 | 11:25 AM
Gokou104's Avatar
I can pretty much can started every time, but it stays on about 3200 sometimes a little bit down and stalls after 5 minutes of running. The bad part I just find out is that tuner studio is not reading the RPM's right on the laptop show like 5800 and the car is at live 3200 so all the tables are way off.
Aaron do you know how to calibrate this??? I'm lost in space now.
Old Aug 27, 2011 | 11:27 AM
Gokou104's Avatar
Post an MSQ.
Aaron I don't know how to monitor the AFRs I'm not that familiar with it.....
Old Aug 27, 2011 | 02:31 PM
Gokou104's Avatar
never mine with the cal. I got it fix
