interior lights fader not working
Old Jul 14, 2002 | 09:38 PM
trigeek37's Avatar
I installed some gauges yesterday, and sence then, my fader does not work. all the lights still work?
any ideas?
btw, I tied the gauges into the light in the cig lighter thingie if that helps any...
Old Jul 14, 2002 | 09:53 PM
maxcooper's Avatar
WWFSMD
Did you connect both wires from the gauges to both wires to the ash tray light? You have to connect both or it won't work. If you ground a wire it will screw up the dimmer circuit. If you have electronic gauges that have a common ground for the illumination and electronics, it is much harder to setup, but can be done. Go here for details:
http://www.scuderiaciriani.com/rx7/e...iring.html#DIM
-Max
