Front Rotor getting weak spark....
Old Jul 14, 2011 | 01:14 PM
CobraStngSVT's Avatar
Team SR
FL Front Rotor getting weak spark....
I am getting weak spark to the front rotor and decent spark to the back (but clearly better). The car is SCCA ITA prepped. Brand new plugs... My initial thought was the ignitors or coils but then the problem would be trailing/leading, not isolated to the same rotor. The car won't start due to this issue.
I also cleaned the leads on the rotor inside the distributor cap but it is slightly worn... could it be this, or maybe the pickup inside the dist.? What else could cause this issue???
Thanks!
Old Jul 14, 2011 | 01:45 PM
t_g_farrell's Avatar
Waffles - hmmm good
Swap the plug wires front to rear. If it follows then its the wires for sure. If it doesn't your
looking further back in the ignition, like cap and rotor.
Old Jul 14, 2011 | 04:44 PM
Team SR
cap and rotor was cheap enough and seemed to have fixed the problem. Just gotta figure a few more things out now. Thanks!
Kyo
Apr 13, 2019 09:24 AM
astrum
24
Nov 15, 2017 08:44 AM
