Air pump (yes I searched)
Old Jul 14, 2002 | 11:42 AM
emagdnim's Avatar
And thorugh the search everything said something different. So here's the deal, I have an '86 GXL N/A and I want to remove the air pump and cats, but I want to keep the 5th and 6th ports. If I get the Racing Beat presilencer/cat replacement pipe can I keep the ports? How do I set that up? What's the process for removing the air pump on the '86 GXL and setting up the ports to still work with the presilencer?
Old Jul 14, 2002 | 01:20 PM
emagdnim's Avatar
Gah anyone?
Old Jul 14, 2002 | 01:28 PM
Aaron Cake's Avatar
Engine, Not Motor
The 5th and 6th port system on the '86-'88 has nothing to do with the airpump. Loose the air pump, then loose the ACV. I believe that all the racing beat cat replacement stuff has a port to actuate the 5th and 6th ports, so everything should still work as designed.
Old Jul 14, 2002 | 04:56 PM
emagdnim's Avatar
Alright, how do I "loose" the ACV? I read something a bout a EGR in search, what about that?
Old Jul 14, 2002 | 05:56 PM
emagdnim's Avatar
Nevermind, I found it, although an v-FAQ or HOWTO (with pictures) for the EGR and ACV would be nice if you know of any..
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
