Running down a Ferrari F430 challenge racecar
Old Jun 18, 2011 | 08:58 PM
tinner's Avatar
A quick vid from Nelson Ledges Road Course.
http://www.youtube.com/watch?v=6l5S7VAI-z4
Camera car, my V6 powered FC. Limited by my racing class to 185 rwhp and 2850lbs.
Old Jun 18, 2011 | 10:16 PM
Spirit-RE's Avatar
what for a v6?
Old Jun 18, 2011 | 10:33 PM
SayNoToPistons's Avatar
Insane Burning Diarrhea
ANy reason why the F430 Challenge was slower than usual?
Old Jun 19, 2011 | 04:03 PM
87 t-66's Avatar
not a drifter
your car is sweet...we need to meet up sometime. i also live in columbus
Old Jun 19, 2011 | 04:40 PM
Hypertek's Avatar
Slowpoke
could you share some info about your car, suspension, tires, engine .
Old Jun 19, 2011 | 08:41 PM
tinner's Avatar
He was running pretty quick and consistent. But both the Ferrari and my car were not optimized for a track as rough as Nelson
I'll be at Mid Ohio for the NASA event in July, stop by and check out some racing. Better yet, sign up and drive on one of the best road courses in the US
1998 GM 3.8 90 degree V6 detuned to 185rwhp
2850lbs. including driver, fuel, and 220lbs. of ballast
225/45/17 BFG R1s
Stance coilovers 10k front 8k rear springs
1 1/8" front sway bar, no rear bar
Old Jun 20, 2011 | 02:22 PM
sharingan 19's Avatar
Rotary Revolutionary
Any particular reason you chose to de tune a v6 as opposed to going w/another motor? Perhaps one that's lighter, offers better weight distribution, or is easier to mount? I mean you can make 185whp w/ anything
Old Jun 20, 2011 | 03:21 PM
arghx's Avatar
rotorhead
I mean 185rwhp... that's a stock T2 with a downpipe
Old Jun 20, 2011 | 03:34 PM
RotaryEvolution's Avatar
Sharp Claws
did they chop the F430 engine in half for this challenge? it should have 2.5 times the horsepower you do yet you were pulling on them in the straights, that should not happen... gotta love pansy *** rich people who can't drive.
the F430 challenge cars also weigh less than your 2850lb curb weight at 2701lbs curb weight, there's no reason they should be lagging behind unless they had governor's installed to keep the throttle from going further than 20%.
i just don't get it, unless they were instructionals.
Old Jun 20, 2011 | 03:35 PM
dwb87's Avatar
This is my social media.
That was an awesome video. I like it a lot.
Old Jun 20, 2011 | 03:38 PM
RockLobster's Avatar
Let's get silly...
Because class rules only dictate peak generated WHP to determine class (in very simplified terms).
So a torquey motor with a fairly flat power curve is ideal. To give you an idea, the most dominating cars in these classes are sometimes boosted cars that run high boost at low rpm but bleed it off as the RPMS rise to have a flat power curve...
Old Jun 20, 2011 | 04:00 PM
SpeedOfLife's Avatar
rotors excite me
interesting. 180hp flat from 2000RPM to 8000RPM would be significantly faster than 160 at 3000 growing to 185hp at 8000
Old Jun 20, 2011 | 05:30 PM
FC3S Murray's Avatar
5 and counting.
Yep. Instant torque too.
Old Jun 20, 2011 | 05:36 PM
tinner's Avatar
Why don't you just come out and say you prefer rotaries. I like them too, but for what I do the V6 offers many advantages. The car is better balanced with the V6, lower center of gravity too. It has loads of torque and is ridiculously reliable.
We were both running laps averaging over 90mph. Look closer he was putting buslengths on me in the straights. He may be rich but he wasn't being a pansy. It takes ***** to hustle a car around Nelson Ledges, some drivers refuse to race there claiming it's too dangerous.
Old Jun 20, 2011 | 07:29 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
^That track looks brutally rough. You can tell in the video the whole car is bouncing.
Old Jun 20, 2011 | 08:38 PM
While, I do that was not my point (if it was I would have said so). I was just curious as to what benifits could be retained by underutilizing a heavier engine, as opposed to lighter one. I was thinking more along the lines of a 4cyl or 4cyl turbo actually since you certainly don't need 6cyl for 185hp. You answered my question.
Well if the track is that much of a beast that it made those 2 cars look remotely equal then my hat goes off to you sir!
Old Jun 20, 2011 | 08:54 PM
texFCturboII's Avatar
version 2.0
Definitely... there were some straights that he was becoming a speck.... he definitely let you by; but still, nice racing; good lines and good throttle control; that track looks freaking terrifyingly rough.
Old Jun 21, 2011 | 11:04 AM
Let's get silly...
Yeah except that you spend your entire time above 5000rpm regardless of the engine...5hp at the top will make the difference.
185 flat from 5000-8000 is the ideal situation, but really only possible with electronically controlled forced induction...
Old Jun 21, 2011 | 04:57 PM
tinner's Avatar
My curve is pretty flat but stops just past 5000rpm
I'm as jealous of your guy's RPMs as you might be of my torque.
Old Jun 21, 2011 | 06:02 PM
Let's get silly...
I've been keeping an eye out for a V6/6speed out of a 2011 mustang...that would be a nice swap...and before long they will be EVERYWHERE in wrecking yards/ebay/craigslists...
Old Jun 21, 2011 | 06:03 PM
Let's get silly...
Hmm that is a low redline...That's TDI territory!
The Shaolin
Sep 14, 2015 07:50 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
