Headlights stuck
Old Jul 12, 2002 | 05:07 AM
Headlights stuck
Ever since I bought my car the headlights are stuck in the up position. You can remove the fuse and screw them down, but I am wanting to fix them. The guy I bought it from said that he replaced the switch in the dash, And gave me the old switch. What should I check? Are there any other switches after the main light switch? Any help is appreciated.
Old Jul 12, 2002 | 05:08 AM
Also, my wiper switch is screwed. I have only "low" and I have to Stop them where I want them. they dont return to the bottom position. And I have no rear wiper power. ....
Old Jul 12, 2002 | 05:10 AM
SonicRaT's Avatar
Super Raterhater
The wiper switch you will have to either replace, or fix (check out http://www.fc3s-pro.com) As far as the headlights go, do they move up when you screw them down and hook up the fuse/battery? They come up if your headlights are on as well, is that switch bad too?
Old Jul 12, 2002 | 06:11 AM
yes, if i pop the fuse in after I have screwed them down, They pop up. If the fuse is in, the headlights are always up.
Old Jul 12, 2002 | 08:48 AM
'Vert in Vegas's Avatar
There is a switch on the instrument panel that 'locks' the lights up for cleaning.
Could that be on?
Old Jul 12, 2002 | 10:23 AM
Josepi's Avatar
Despise Enmity
Could that be on?
That'd be too funny. It's below the defrost for the rear, and above the headlight switch.
Old Jul 12, 2002 | 02:59 PM
I must assert at this point I am not an idiot. lol
renjiv2
57
Jan 25, 2024 03:34 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
