window regulator self install
Old Jun 5, 2011 | 11:34 AM
nguz26's Avatar
NJ window regulator self install
I recently purchased a power window regulator for my 1991 mazda rx7 convertible. How hard is it to mount this piece myself? If its possible to self install it, I would be saving a lot of money avoiding a mechanic.
Old Jun 5, 2011 | 01:07 PM
RotaryRocket88's Avatar
Top Down, Boost Up
I guess the answer would depend on how mechanically inclined you are. It's not that time consuming, but it can be somewhat of a hassle. The glass must be partially down to be able to remove the mounting hardware & window stops, then once the glass has been removed from the top, you'll have to remove the regulator/motor assembly through the largest opening in the door. It's a tight squeeze. When everything is reassembled, some adjustment of the mount and stops will be needed to make sure the window seals properly at the top.
Old Oct 29, 2011 | 05:51 AM
iansinger's Avatar
You say leave glass in then you say take out. It can stay in to remove the regulator. I am having trouble getting new one in and can't line up the motor with its mounting holes. It would be nice if I could see what I was doing.
When I bought the car the drivers regulator was broken and the window glass was propped up by a block of wood.
Old Oct 30, 2011 | 04:02 PM
Top Down, Boost Up
Tell me where I say the glass must be left in? Read the post again. Removing the window will make getting the regulator assembly in/out a hell of a lot easier. There won't be a need for a block of wood jammed inside to hold the glass up.
Old Oct 31, 2011 | 12:03 PM
iansinger's Avatar
This says take glass out. but it is not needed to replace regulator. I just can not get the motor back in and lining up. Remember this is convertible so window mechanism is different to sedan.
I never said I put a 2x4 in. I said the previous owner did and left it in to keep window up as he only drove with top down.
Ian Singer
bURGRotary87
Aug 19, 2015 03:54 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
