starter question
Old Jul 11, 2002 | 10:38 PM
HuggyBear's Avatar
starter question
are the 88 turbo and n/a starters the same?
i just got done with a conversion to 88t2 tranny and stuck an n/a starter in it. bolted up fine. struggled to start it every time, but i thought it might be a starter problem since it was used and it was the only one available at the time.
now the starter is dead and im wondering if it might be because it wasnt compatible with the 88t2 tranny.
help...
btw this was all done on a 90gxl
Old Jul 12, 2002 | 04:16 AM
HuggyBear's Avatar
bump
Old Jul 12, 2002 | 10:32 AM
Icemark's Avatar
No they are not the same on manual tranny versions,
However I have been told that the NA auto starter is the same as the T2 starter... but weither or not that is true, I can't tell you.
Old Jul 12, 2002 | 12:40 PM
HuggyBear's Avatar
im a starter newb here. is the starter tranny dependant or is it engine dependant? im guessing it would be tranny dependant but im not usre. can someone snwer that for me?
Old Jul 12, 2002 | 02:37 PM
Rob500's Avatar
I did the auto - T2 5 speed conversion. The automatic starter and the T2 starter are not the same. The T2 starter has a longer nose. I have swapped out the starter motors with no apparent difficulty.
Rob
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
