Microtech possible problem with my lt-10s
Old May 29, 2011 | 02:49 PM
Laz93RX7's Avatar
All Hail the Magic Conch!
Question possible problem with my lt-10s
had my microtech lt-10s for 5 years now, no problems until recently a few weeks ago car wouldnt start would turn over but not start.
car is a 93 mazda rx7 13b single turbo.
checked for spark, OK
checked checked for loose connections, OK
checked fuel system,OK
checked and tested injectors,OK
last checked compression, OK
put everything back together went to start, it starts. working fine the past few weeks went to start it today again same symptoms engine turns over but doesnt start. have no idea what it could be please help.
Thanks,
Lazaro
Old May 29, 2011 | 02:50 PM
Laz93RX7's Avatar
also spark plugs are dry even after trying to turn over the car for awhile.
Old May 29, 2011 | 05:23 PM
flaco's Avatar
prime the injectors and try again also check the tps make sure is calibrated
Old May 29, 2011 | 05:38 PM
Laz93RX7's Avatar
tried no luck, tps is calibrated.
Old May 29, 2011 | 07:03 PM
flaco's Avatar
you sure you got spark?
Old May 29, 2011 | 08:52 PM
Laz93RX7's Avatar
yes have spark.fuel pump is working, have fuel pressure. have good comp. the only thing that I can notice is the plugs are dry even after cranking several times.
Old May 30, 2011 | 11:51 AM
flaco's Avatar
what if you spray some starting fluid thru the intake?
Old May 30, 2011 | 06:12 PM
Laz93RX7's Avatar
havent tried that.
Old May 30, 2011 | 10:16 PM
rxspeed7's Avatar
F-IT
do the leds on the unit light up? green for power, yellow mimics ign output, red for any errors.
Old May 31, 2011 | 06:12 AM
Laz93RX7's Avatar
checked for errors all ok.
got green and yellow no red?
Old May 31, 2011 | 10:52 PM
flaco's Avatar
spray some starting fluid , and check your coolant sensor . might be reading wrong
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
