Power FC Base Map needed for 850/1600 idling way too rich!
Old May 25, 2011 | 07:07 AM
Satsuki_FCsanS's Avatar
MD Base Map needed for 850/1600 idling way too rich!
i just got my power fc installed in my FC. Banzai hooked me up with a base map but it idles way too rich. At idle my wideband read 9.0! i dont have access to a datalogit so i just needed something to get me around for a few weeks til my tuner is free. any input will help thanks.
Old May 25, 2011 | 09:39 AM
arghx's Avatar
rotorhead
It could be that it just needs tuning (no guarantees with any basemap), but are you sure you don't have a major vacuum leak or some other problem? Without a Datalogit you can't load anything up anyway.
Old May 25, 2011 | 11:03 AM
Banzai-Racing's Avatar
Rotary Specialists
You can't load alternate base maps without a datalogit. If it is running that rich there is something else wrong. The base map supplied to you was developed on a dyno for a car here at the shop, it would still need tuning but it will not be that far off. Check your base fuel pressure, make sure it is set at 40psi not running with the fuel pump jumpered.
Old May 25, 2011 | 11:06 AM
tom94RX-7's Avatar
Did you go into your commander and lean out the portion of the inj. Map where it idles? That should help. But it will still idle rich with 850s. I was glad I switched back to 550s after having the 850s in there.
Old May 25, 2011 | 05:20 PM
the_glass_man's Avatar
Will u do me a kindness?
Also check the map to make sure it's set up for the correct MAP sensor. Are you running stock or a 3 Bar?
Old May 26, 2011 | 10:22 AM
just did a sensor check on my power fc and the O2 sensor has no voltage? whats the voltage for a functioning o2 sensor?
Old May 26, 2011 | 10:25 AM
im running a 3 bar map
Old May 26, 2011 | 10:30 AM
tom94RX-7's Avatar
Go into your commander and turn off the o2 function and see if that helps. Most people turn that off anyway and you don't need the o2 sensor working
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
20B Forum
Aug 19, 2015 01:47 PM
