Super AFC Area is for discussing the Apexi Super AFC
Super AFC 13b streetport na with safc
Old May 23, 2011 | 09:03 AM
julesfc3s's Avatar
QC 13b streetport na with safc
I plan to streetport my 13b and i want to know if a safc will drive it corectly.
thanks
Old Jun 21, 2011 | 08:38 AM
Snoopy240's Avatar
Mr.
Yes. I have:
13b six port, large street port
Header-exhaust no cat
No aux ports
S5 intake, VDI wide open
CS intake tube
Filter
Freshly cleaned stock injectors
wideband, vac gauge, SAFC II
And I tuned it without a problem
Old Jun 26, 2011 | 05:03 PM
julesfc3s's Avatar
QC
thanks
Old Jul 3, 2011 | 12:54 PM
rx7freak13v's Avatar
I'm thinking about getting an apexi safc2 neo. I need to lean out a lot and can't afford a stabdalone right now. I've heard a lot of mixed feelings about the safc. Heard it doesn't adjust factory timing and others say it does, can u clear this up for me please? Would u recomend it?
Old Sep 15, 2011 | 12:06 AM
suck_my_rotor's Avatar
*Currahee Performance*
what setup are you running? the safc can lean/rich your afr, but only to an extent. its a very basic tuning device. for example, a good candidate would be like a turbo 2 with rtek1.7, an safc, and a wideband. but if you need to lean out a lot, just save up and get a standalone. and the safc does not adjust ignition timing. i hope this helps
Old May 10, 2012 | 01:09 PM
em55ron's Avatar
Great for budget build
Old May 26, 2013 | 09:18 PM
julesfc3s's Avatar
Hi everybody my engine is running. But i need more fuel on low throtle and i allready add 50% more. Somebody have a solution ??
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Robrods64
Oct 2, 2015 07:56 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
