91' Vert N/A- Limp Mode
Old May 20, 2011 | 02:19 PM
iFayt's Avatar
CA 91' Vert N/A- Limp Mode
Hey guys, so I just picked up a 91' Vert N/A and it ran perfectly for a day after I bought it. The next day I drove it, it ran perfectly until the car started to bog. The engine light came on and I figured it was bad. Limp mode
I checked the engine codes: 1 12 17 18 27 37
My friend and I thought it could be an O2 sensor problem, so we changed that, but that didn't solve anything.
We then tried to use a spare s5 OMP, it still gave the same codes. (maybe it was bad)
After all of that, I went to the local pick-n-pull and grabbed a n352 ECU. I haven't installed it yet, but I'm afraid of blowing it.
I looked all over the forums, and even talked to my local rotary peeps, and they don't know what the problem could be.
So, does anyone know what the issue may be? Any and all help would be greatly appreciated.
Old May 21, 2011 | 12:28 AM
RotaryRocket88's Avatar
Top Down, Boost Up
http://www.johnr.com/cpucodes.html
01 - Ignition Coil (Trailing) - Trailing ignition pulse cut
12 - Throttle Sensor (TPS) Full Range - Fixed at 20% open
17 - Feedback System (poss O2 sensor) - Feedback cancelled
18 - Throttle Sensor (TPS) Narrow Range - Fixed at full-open
27 - MOP (General) - Basic Fuel Injection and fixed timing
37 - MOP (General) - Basic Fuel Injection and fixed timing
That's a lot of problems, but the only one that will cause limp mode is a bad MOP. Often a failed MOP will burn out part of the ECU when it goes. You'll need to replace both at the same time.
The trailing coil and TPS problems will affect driveability.
Old May 21, 2011 | 12:53 PM
iFayt's Avatar
By replacing the ecu and the omp, and getting rid of limp mode, will it get rid of the tps and ignition coil problem?
Old May 21, 2011 | 01:13 PM
funkjaw's Avatar
^ It's possible.... but it doesn't hurt to check your TPS and Coils to make sure they are within specifications.
rxlevi7
Sep 26, 2015 07:28 AM
MidnightOwl
Sep 25, 2015 10:24 PM
