89 Turbo II idle woes.
Old May 19, 2011 | 09:33 AM
m.gresham's Avatar
Hello all,
Lemme start by saying yaayyyy!!! Back in a Rotary. Originally had a 91 Gtu. 8 years later and now I'm back. 89 Turbo II (my dream), runs great when shes warm, wont idle or stay running cold, even after it warms it has a chaotic idle. Usually will float around the 1600rpm range. I've had it for a year, put a new motor and trans from jspec auto in it (still had the problem). 3" racing beat exhaust from turbo to hks cat back. No other mods. P/s and A/c are gone, as well as Idle air control and emissions components, there is also a significant exhaust leak at the turbo where the downpipe mounts due to poor machining of a wastgate dump plate. This may just be an issue I have to deal with til I buy the engine management I want, but I dont know for sure if it could just be the exhaust leak, map sensor goin out. I've seen other turbo rex's idle with no problem without a IAC and come to find out it was simple throttle body adjustments. Any advice would be great.
Thanks.
Old May 19, 2011 | 11:32 AM
RotaryRocket88's Avatar
Top Down, Boost Up
Removing the BAC and thermowax means you're going to have to give it some throttle cold. That's all there is to it. This is a big reason to not remove those things.
After warming up, if the idle bounces it is most likely one of two things: vacuum leak/air leak or TPS out of adjustment/bad.
Old May 21, 2011 | 12:17 AM
fire0wl's Avatar
Just today , Found a vacuum going to nothing, and adjusted the TPS. Does not idle erratic anymore now.
Old May 21, 2011 | 10:01 AM
Aaron Cake's Avatar
Engine, Not Motor
Do yourself a favor and put the BAC back on. There's no reason to remove it.
Old May 21, 2011 | 01:14 PM
funkjaw's Avatar
^ I second that.
Old May 23, 2011 | 08:26 AM
m.gresham's Avatar
After re-installing said BAC, still has the same problem...how do I troubleshoot the component for functionality??? or have I just kinda done that...
Old May 23, 2011 | 10:30 AM
Aaron Cake's Avatar
Engine, Not Motor
Vacuum leaks? During emissions removals, many people mess up the vacuum system so badly that the car doesn't run correctly ever again without a total vacuum system replacement. Idle problems are almost always vacuum related.
There are instructions for testing the BAC in the Haynes and FSM.
Kyo
Apr 13, 2019 09:24 AM
smikels
Rtek Forum
May 12, 2016 12:34 AM
incubuseva
14
Sep 3, 2015 12:37 PM
