Need Help, swap 13b t2 on RX3?
Old May 18, 2011 | 02:35 PM
rx3gt's Avatar
This is my RX3 74. And I started to put the engine but the turbo does not fit into the chassis, someone has an idea that I can do.
Attached Thumbnails Need Help, swap 13b t2 on RX3?-dsc00104.jpg   Need Help, swap 13b t2 on RX3?-dsc00123.jpg   Need Help, swap 13b t2 on RX3?-dsc00124.jpg
Old May 18, 2011 | 02:54 PM
PureMdMa's Avatar
1 of 203 94 White PEP's
I always wondered how this would fit, looks like you need a aftermarket manifold, or can you rotate the intake side of the turbo?
Old May 18, 2011 | 06:15 PM
bwaits's Avatar
Needs More Noise
Most guys move the turbo up and forward with an aftermarket manifold. Something like this:
Old May 19, 2011 | 10:27 AM
Aaron Cake's Avatar
Engine, Not Motor
Rotate the compressor housing a little to move the wastegate actuator, then fab up a new rod.
Sorry, this is my fault from the New User forum. I didn't think you'd be using a stock turbo.
Old May 19, 2011 | 11:21 AM
rx3gt's Avatar
Thanks, I will first try to turn the compressor housing, if you are not, I will get a aftermarket manifold.
Old May 19, 2011 | 11:24 AM
rx3gt's Avatar
Thanks, this is my second choice.
Old May 19, 2011 | 11:32 AM
rx3gt's Avatar
Aaron Thanks for your help, no problem, your advice I have been very helpful.
Old May 19, 2011 | 11:57 AM
AuthoritySucks's Avatar
RollinRock
Notch out that mono frame. Lol.
Old May 19, 2011 | 12:23 PM
rx3gt's Avatar
It's a great idea, but NO THANKS.
Old May 19, 2011 | 07:53 PM
74MZDRX3's Avatar
Too many toys
i relocated the waste gate actuator. cut the rod. theaded it with a 1/4 20 die and coupled it witha rod connector and nuts. i havn't finished my rx3 stuck on wiring harness.
Old May 19, 2011 | 07:57 PM
74MZDRX3's Avatar
Too many toys
I had an issue with the stock oil return line clearing the new actualtor braket.
please note i haven't tested this mod. i measured alot before cutting.
Attached Thumbnails Need Help, swap 13b t2 on RX3?-dscf0015.jpg   Need Help, swap 13b t2 on RX3?-dscf0016.jpg   Need Help, swap 13b t2 on RX3?-dscf0017.jpg
Old May 21, 2011 | 01:59 AM
REPU_74's Avatar
or u can buy this:
https://www.rx7club.com/west-sale-wanted-classifieds-195/s4-turbo-custom-header-rx2-rx3-rx4-repu-rx7-fb-fc-954456/
Old May 24, 2011 | 12:43 AM
Gilgamesh's Avatar
I totally notched and boxed a section of the frame.
now im going hx40. I bought a cheap ebay mani like pictured above and the turbo wont clear the fender well. the flange needs to be more of a top mount.
Old May 24, 2011 | 10:49 AM
rx3gt's Avatar
Thanks everybody, I´m trying the 74MZDRX3 advice.
Old May 24, 2011 | 07:38 PM
Gilgamesh's Avatar
not the best pic in the world but its snug
Old May 29, 2011 | 08:09 PM
13BT_RX3's Avatar
The General RE
Were you planning on making the turbo back exhaust system yourself? If so, while you at it you could make a pipe that bolts between the turbo and the stock manifold to relocate the turbo up a bit. You would just need two flanges & a J-bend to make such an adapter.
Old Feb 28, 2013 | 08:49 PM
treceBturbo's Avatar
i kno its a very old post but o well.. maybe it can help someone else
all of my buddies. just use one turbo 2 motor mount and one rx3 mount and it gives enough clearence to run until you get the money for a BNR which has a smaller vacuum actuator and will clear the frame.
-eddie
Old Mar 6, 2013 | 05:44 AM
hypestar1983's Avatar
right on time, you just helped me
Old Mar 6, 2013 | 06:29 PM
im glad i was able to help. im in the middle of a turbo II swap in my 3. finally have enough money haha. good luck to you
Old Mar 6, 2013 | 07:04 PM
bumpstart's Avatar
talking head
oz sourced manifolds bring it forward and up to clear chassis and steering box...
since you dont have to go quite as far forward.. a simple trick is to use the stock s5 turbo manifold.. flip it upside down and bolt it to the engine
this moves the turbo up a little and adjacent the front rotor
on the turbo,, you have to oval two of the holes to make it fit ..
compressor cover will now just kiss the inlet manifold.. you can use a spacer plate and two gaskets ( 16mm ish ) between manifold and turbo .. or you can grind the inlet manifold
PS you can use one tall and one short mount.. FC modles have a slightly taller mount ,, you can put a shim plate either side
also /.. some FC3s models have a taller mount on spark side than than others
Old Mar 6, 2013 | 07:08 PM
bumpstart's Avatar
talking head
also you can flip around your timing cover engine bracket and thus offset engine with bias slightly to either side of bay
befarrer
Oct 5, 2015 03:30 AM
