Can I change mounts?
Old Jul 11, 2002 | 08:40 AM
montrealgtu's Avatar
Being of avarage mechanical competence.....
Can I easily change my motor and transmission mounts? Anything I should be aware of?
Thanks
Old Jul 11, 2002 | 08:44 AM
rico05's Avatar
WTB S5 N/A FC
Can you use an engine hoist? Ok then....you can do this. I would use a engine hoist to get at the mounts, and while the engine is on the hoist, just loosen all the mounts you want to replace and swap em out!
Old Jul 11, 2002 | 08:54 AM
No hoist, but Haynes says to support the motor from underneath using a jack and a wide plank of wood to distribute the weight. This sounds like trouble, but if I'm only doing one mount at a time?
Old Jul 11, 2002 | 09:11 AM
rico05's Avatar
WTB S5 N/A FC
That can also be done as well, but the hoist is just easier if you have one. Just loosen all the mounts at once, and then jack it up.
Old Jul 11, 2002 | 09:27 AM
thanks, I'll give it a try. Most garages are closed for two weeks anyway for the construction holiday, so I don't have much choice.
Old Jul 11, 2002 | 09:31 AM
rico05's Avatar
WTB S5 N/A FC
It should be easy. Why do you need to change your mounts?
Old Jul 11, 2002 | 09:36 AM
as one indication, my shifter bounces up and down a lot on rough roads, and I got 40% discount on motor and transmission mounts, so why not? I'm at 100, 000 KM now so I figured it couldn't hurt.
Old Jul 11, 2002 | 09:37 AM
KNONFS's Avatar
B O R I C U A
I don't know about the engine mounts, but the tranny mount is very easy, all I used was the oem jack lifter (is that the right word?)
Old Jul 11, 2002 | 09:47 AM
Yah, it doesn't look too involved, but I just wanted to know if I was going to run into any trouble.
Thanks, I'll let you know how it goes...
Skeese
65
Mar 28, 2017 03:30 PM
Boriquaguerrero
Comments and Suggestions Archive
Aug 19, 2015 01:01 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
