Vendor Classifieds For vendors to list their items for sale
Digital Torque Wrench Member Special !!
Old May 17, 2011 | 11:45 AM
BLMW's Avatar
Registered User
As an introductory special, we are offering our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: www.brownlinemetalworks.com and click on the "Buy Now" button. At checkout, enter the coupon code: RX7.
You can see the torque wrench in action on the video on our website. Specs are as follows:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid till June 7th, and is only for the lower 48 states.
Old May 20, 2011 | 01:03 PM
zeeshan's Avatar
AWESOME. Will be placing an order soon.
Old May 20, 2011 | 02:15 PM
Max_Spd's Avatar
UA DRVN
Just placed my order!!! :-)
Old May 24, 2011 | 11:23 AM
BLMW's Avatar
Registered User
Video
So you can see it in action - here is the video link......
[youtube]cEJsE2vlxxE[/youtube]
Old May 24, 2011 | 11:41 AM
magus2222's Avatar
On the fasttrack!
id like to get a good digital torque wrench, but does this have life-time (the life of the tool) warranty?
if something happens to it, who fixes it?
will someone calibrate it if or when i need it?
also, it seems to me that this particular tool has a sort of low range for a 1/2 drive, its almost like a 3/8" drive with a bit higher range.
also, with 32 teeth and an arc of 11.25 degrees, isnt that a bit of a wide arc?
yet also, does it do torque angle for precise head work?
Lloyd
Old May 25, 2011 | 12:39 PM
BLMW's Avatar
Registered User
Questions
The warranty on our wrench is industry standard: 1 year, 90 days for calibration. We do repairs and calibration, if necessary, in Chicago.
Typically, a 3/8" drive torque wrench will handle up to 100 ft.lbs. We felt that we wanted to cover up to 150 ft.lbs, as this was the maximum range we thought the majority of DIY mechanics would need. We felt that the user could use an adapter if a 3/8" drive was required.
Our wrench does measure angular rotation.
Please let me know if you have any additional questions.
BLMW
Old May 25, 2011 | 03:37 PM
Supernaut's Avatar
OOOOOOO nice.
Old Jun 2, 2011 | 01:37 PM
LongRX7's Avatar
Set myself a reminder to order on Monday
Old Jun 3, 2011 | 11:16 PM
Brigdh's Avatar
What kind of batteries does it take? How are they accessed?
Old Jun 4, 2011 | 02:01 AM
Max_Spd's Avatar
UA DRVN
3 x AA fitted in rear section, instructions come with the unit!!!
Old Jun 8, 2011 | 03:28 PM
BLMW's Avatar
Registered User
Member Special Extended...
Thank you so much for the great response. We have decided to extend the deadline until June 16th.
BLMW
Old Jun 14, 2011 | 10:54 AM
LongRX7's Avatar
I bought one and shipping was fast. Looks great..haven't had a chance to use it yet.
Old Jul 8, 2011 | 01:22 PM
banzaitoyota's Avatar
What Subscription?
Any chance on a repeat of the special?
Mazda84GSLSE
13
Apr 27, 2018 07:35 PM
foxbod88
Sep 23, 2015 09:07 AM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
